Right - Here it is
EYE OF THE ROBOT - SERIES 1
This is the start of a new era of fictional roboteering. Inspired by the FightingRobots fan fiction forum, I€™ve made a new tournament - Eye of the Robot (E.O.T.R). This is a great task for me to learn to write longer things, and put more effort into what I do, and not rush it.
The competition is 6 rounds with 12 heats, and 6 robots in each heat. This set up is like this
HEATS
R1 - 2 x 3 ROBOT MELLES, TWO GO THROUGH
R2 - 2 x 1 ON 1, TWO ROBOTS GOES THROUGH
R3 - 1 x 1 ON 1, ONE ROBOT GOES THROUGH
FINALS
R4 - 6 x 1 ON 1, 6 ROBOTS GO THROUGH
R5 - 2 x 3 ROBOT MELLES, 2 ROBOTS GO THROUGH
PLAY-OFF - ONE 4 ROBOT BATTLE
R6 (GRAND FINAL) - 1 ON 1.
I will give 11 realies (this may increase later on) to reduce vapour numbers - they are:
VOLTRONIC
TURBULENCE
STORM 2
TORNADO
GRAVITY
TERRORHURTZ
FIRESTORM 5
BEHEMOTH
BIG NIPPER
BULLDOG BREED
DANTOMKIA
I will also enter eight of my robots to help as well.
TEAMS AND THEIR ROBOTS
TEAM €˜Italian Stallion€™
TURBO TERRA
€ WEIGHT: 95KG.
€ ARMOUR: 12MM HARDOX/ 12MM TITANIUM
€ SHAPE: LOW INVERTIBLE CYLINDER-LIKE
€ MOTORS: 4 x 800WATT MOTORS = 2.2HP
€ LOCOMOTION: 4 x FOAM WHEELS
€ DIMENSIONS: (W) 60CM (L) 60CM (H) 25CM
€ COLOUR: BLUE WITH ORANGE TIGER STRIPES
€ WEAPONRY: 60KG FULL BODY SPINNER, 2300RPM WITH 16 4CM CURVED STEEL TEETH. 426KJ OF ENERGY
€ SPEED: 14MPH.
€ GROUND CLEARANCE: 10 MM.
€ STRENGTH: POWER AND WEIGHT OF WEAPON.
€ WEAKNESS: PUSHING POWER. 2 SECOND SPIN-UP TIME
SCHMAX
€ WEIGHT: 95KG
€ ARMOUR: 5MM HARDOX ON SIDES/FRONT/BACK. 7MM POLYCARBINATE ON TOP.
€ SHAPE: INVERIBLE BOX WITH FRONT POINTED WITH CUT-OFF END FOR PUNCHER
€ MOTORS: 6 x 750WATT AT 24V = 6HP (GEARED FOR 12HP)
€ WHEELS: 6 x SLICK WET GO-KART TYRES
€ DIMENSIONS: (W) 50CM (L) 60CM (H) 20CM
€ COLOUR: FRONT/SIDES/BACK; BLUE WITH ORANGE TIGER STRIPES. TOP; SLIGHTY GREEN
€ WEAPONRY: 12KG HYDRAULIC PUNCHING RAM. 200 MPH TOP SPEEDS. THREE WAY SCOOP WITH EXTENSION
€ SPEED: 16MPH
€ GROUND CLEARANCE: 2 MM
€ STRENGTH: SPEED AND POWER. STRONG WEAPON
€ WEAKNESS: HARD TO CONTROL
INVERTEX
€ WEIGHT: 96KG
€ ARMOUR: 13MM TITANIUM
€ SHAPE: SHORT BODY WITH SPIKED WHEEL-GUARDS AND CURVED ENDS
€ MOTORS: 2 x 2.5 KW AT 24V. = 4HP
€ LOCOMOTION: 4 x SLICK WET GO-KART TYRES
€ DIMENSIONS: (W) 30CM (L) 40CM - WITHOUT FLIPPER 80CM - WITH FLIPPER (H) 40CM
€ WEAPONRY: 1000PSI FLIPPER. DUAL RAMS. 3 TONS FORCE ON THE SCOOP, 5 TONS IF FULLY UNDERNEATH OPPENENTS
€ SPEED: 13MPH (HIGH ACCELERATION)
€ GROUND CLEARANCE: 0MM
€ STRENGTH: STONG WEAPONRY
€ WEAKNESS: IMPOSSIBLE DESIGN!!!
CRUSHER C.U (CUTTING.UP)
€ WEIGHT: 100KG
€ ARMOUR: 12MM TITANIUM/ 5MM TUNGSTEN STEEL
€ SHAPE: INVERTIBLE BOX WITH FRONT FIXED SCOOP
€ MOTORS: 2 x LEM 130 AT 36V = 16HP
€ LOCOMOTION: 8 x SCOOTER WHEELS
€ DIMENSIONS: (W) 40CM (L) 60CM (H) 20CM
€ COLOUR: BLACK WITH SILVER LINING
€ WEAPONRY: SCOOP WITH VACUUMS TO TRAP OPPENENTS. A DOUBLE-SIDED CRUSHER COMES IN, WITH 6 TONNES ON EACH. REAR SPIKES. THE SCOOP IS AT A 22* ANGLE. IT USES A HYDRAULIC RAM FOR SLEF-RIGHTING IF FLIPPED.
€ SPEED: 17MPH
€ STRENGTH: UNIQUE DESIGN
€ WEAKNESS: UNIQUE DESIGN
FLUX
€ WEIGHT: 95KG
€ ARMOUR: BODY - 10MM ALUMINIUM, 12MM BOMB-PROOF POLYCARBINATE, 6MM TITANIUM. SKIRTS - 10MM HARDOX.
€ SHAPE: INVERTIBLE RAMMING BOX
€ MOTORS: 4 x LEM 130 AT 36V = 54HP
€ LOCOMOTION: 4 x VULKOLON WHEELS
€ DIMENSIONS: (W) 50CM (L) 50CM (H) 17CM
€ COLOUR: BODY; BLUE WITH ORANGE STRIPES. SKIRTS; VERTICLE GREEN, WHITE AND RED STRIPES
€ WEAPONRY: NON-FIXED SKIRTS. EACH SKIRT IS 5KG IN WEIGHT
€ SPEED: 26MPH
€ GROUND CLEARANCE: 0MM (SKIRTS)
€ STRENGTH: INVERTIBLE WITH NON-FIXED SKIRTS
€ WEAKNESS: NO DAMAGING WEAPONS
ZEE DRUM
€ WEIGHT: 94KG.
€ ARMOUR: 15MM TITANIUM
€ SHAPE: INVERTIBLE BOX-LIKE WITH OVAL SIDES
€ MOTORS: 4 x LEM 130 24V = 27HP
€ LOCOMOTION: 8 x VULKALON TYRES (2 POWERED PER MOTOR)
€ DIMENSIONS: (W) 55CM (L) 50CM (H) 15CM
€ COLOUR: SILVER AND GOLD
€ WEAPONRY: 30KG HARDOX, STEEL AND TITANIUM DRUM WITH 20 BLUNT TEETH, 3000RPM.
€ SPEED: 25MPH.
€ GROUND CLEARANCE: 0MM.
€ WEAKNESS: SPIN-UP TIME.
HYENA
€ WEIGHT: 100KG
€ ARMOUR: 5MM HARDOX/ 20MM BOMB-PROOF POLYCARBINATE/ 12MM TITANIUM
€ SHAPE: INVERTIBLE RECTANGLE WITH FRONT LOW EXTENSION, SPIKED SIDES AND REAR FLYWHEEL
€ MOTORS: 2 x 3KW AT 36V = 10HP
€ LOCOMOTION: 10 x 15CM VULKALON RUBBER WHEELS
€ DIMENSIONS: (W) 50CM (L) 80CM (H) 14CM
€ COLOUR: GOLD WITH BLACK SPOTS
€ WEAPONRY: AT THE FRONT IS A 5CM WIDE AND 8CM LONG EXTENSION, THIS IS THE FIRST PART OF A JAW SYSTEM. THE SECOND PART WORKS LIKE AN AXE AND IS ANOTHER 5CM WIDE 8CM LONG TITANIUM PLATE. THE JAW IS MADE OF HARDOX WITH 5 6CM TEETH MADE OF ENLIGHTENED HARDOX, AND IS POWERED BY 3 HYDRAULIC RAMS AT 3000PSI (EACH) AND USES VERY FAST RAMMING ABILITES TO COME DOWN AT 300MPH, ENOUGH TO GRIP ANOTHER ROBOT AND CRUMBLE IT€™S ARMOUR. AT THE REAR IS THE SKIRT-KILLING FLYWHEEL - WEIGHING 15KG AND USING 1 x LEM 200 AT 48V TO SPIN AT 2500RPM. 5MM THICK AND MOUNTED 1MM OFF THE GROUND. SIDE SPIKES PROVENT IT GETTING BEACHED.
€ SPEED: 20MPH.
€ GROUND CLEARANCE: 10MM (UNDER SKIRTING)
€ STRENGTH: BRILLIANT WEAPON COMBINATION
€ WEAKNESS: DIFFICULT CONCEPT TO UNDERSTAND
1. Achilles Alex Holt
2. Tengu 7
3. Baldur Gamma
4. Ramthrax 2
5. Black Panther Queen
6. Archangel Of The Abyss
7. Wedge Devolution Steve McGregor
8. Killotine: Evo
9. SD 4
10. Whirligig 4.0
11. Clawdius Decimus Murderous
12. Chameleon
13. Tails
14. Mario Brothers Tony P
15. AK-47 Slapper
16. Shovearound 2
17. Aquarius
18. Agro 3.5 Rich S
19. Death Adder 3
20. Drilla Killa 7
21. MORD 2
22. Snakebite 4
23. SYNDOS
24. Tenderizer€™s Revenge
25. Die Ceratops Re-Invertus Chris M
26. Orka Mk 4
27. Cyclone Force 2.5
28. Leprosy Infection
29. Mega Masher
30. Y4
31. Axe-O-Lotl
32. Obliteration
33. Quocunque Jeceris Stabit Dave S
34. Calm Down Dear (It€™s Only a Robot)
35. Son of Wedgie
36. The Circle Revisited
37. P.C.C
38. Flipping Mad RKACG
39. Chalkie 3G
40. Flippa Frenzay Mk 7 Matty McDonnald
41. No Close Shave 3
42. Not Another pushover 3
43. Ripoff Yet Again
44. Growling Storm 3.5
45. The Axe Attaxe
46. Flaming Hell Dave W
47. Hell Machine
48. Sheer Hell
49. Flipping Hell
50. Jaws of Hell
51. Ed, Edd €˜n€™ Eddy
52. SOR 4.0 Andy J
53. FP 4.0
54. Wedga Revo 2.0
55. GigaByte 1.5
56. The Nose 3.0
57. GeForce Evo 3.0
58. Psyclonic
59. Tempest Evil-er-lution Frank G
60. The Disc 5
LINE UP!!!
HEAT A
Wedge Devolution VS Y4 VS Flipping Hell
Achilles VS Invertex VS Aquarius
HEAT B
ForcePower Turbo VS Storm 2 VS Shovearound 2
Ripoff Yet Again VS Leprosy Infection VS Clawdius Decimus Murderous
HEAT C
The Axe Attaxe VS Terrorhurtz VS Axe-O-Lotl
GeForce VS Hell Machine VS Tempest Evil-er-lution
HEAT D
SD IV VS Psyclonised VS Orka MK.4
Tengu 7 VS Flaming Hell VS Crusher C.U
HEAT E
Behemoth VS Wedga Revo VS Not Another Pushover 3
Whirligig 4.0 VS MORD2 VS Die Ceratops ReInvertus
HEAT F
Flux VS Mega Masher 2 VS Tails
Son Of Ripper 4 VS Snakebite IV VS Archangel Of The Abyss
HEAT G
Tornado VS Baldur Gamma VS Drilla Killa 7
Obliteration VS Killotine: EVO VS Flippa Frenzay Mk 7
HEAT H
Gravity VS SNDOS VS Firestorm 5
Cyclone Force 2.5 VS Giga-Byte VS Turbo Terra
HEAT I
The Nose 3.0 VS P.C.C VS Black Panther Queen
No Close Shave 3 VS The Disc 5 VS Zee Drum
HEAT J
Hyena VS Flipping Mad VS Growling Strom 2.5
Sheer Hell VS LK-47 Slapper VS Typhoon 2
HEAT K
Schmax VS Agro 3.5 VS Turbulence
Jaws Of Hell VS Chameleon VS Quocunque Jeceris Stabit
HEAT L
Dantomkia VS Battle Raptor 4 VS Voltronic
Big Nipper VS Bulldog Breed VS Son Of Wedgie
There is also an annihilator that takes place between the semi-finals and the play-off. Here€™s the draw:
Annihilator
Die-Ceratops ReInvertus VS Wedge Devolution VS MORD2
Big Nipper VS Crusher C.U VS Tengu 7
The Arena
The arena is a hexagon shaped arena with a pit in the top right corner, with the release switch next to it on the left. The pit is in the middle of the arena. On both sides, there are spinning cylinders weighing 200kg each and spinning at 2000rpm. There are 4 on each wall, two spin upwards and two spin right. There are two starting squares are at the top and bottom of the arena. The walls are 1metre high, and robots will go OOTA.
The Judging System
The system has 5 categories: Style, Control, Strategy, Aggression and Damage. It category is 15 points spilt between the robots. E.g. x: 2 y: 13 The points add up to 75 and the winner is the robot with the highest score.
Right - send in your predictions
HEATS
FINALS
VOLTRONIC
TURBULENCE
STORM 2
TORNADO
GRAVITY
TERRORHURTZ
FIRESTORM 5
BEHEMOTH
BIG NIPPER
BULLDOG BREED
DANTOMKIA
TURBO TERRA
€ WEIGHT: 95KG.
€ SPEED: 14MPH.
SCHMAX
€ WEIGHT: 95KG
€ SPEED: 16MPH
INVERTEX
€ WEIGHT: 96KG
€ WEIGHT: 100KG
€ SPEED: 17MPH
FLUX
€ WEIGHT: 95KG
€ SPEED: 26MPH
ZEE DRUM
€ WEIGHT: 94KG.
€ SPEED: 25MPH.
HYENA
€ WEIGHT: 100KG
€ SPEED: 20MPH.
2. Tengu 7
3. Baldur Gamma
4. Ramthrax 2
8. Killotine: Evo
9. SD 4
10. Whirligig 4.0
12. Chameleon
13. Tails
15. AK-47 Slapper
16. Shovearound 2
17. Aquarius
18. Agro 3.5 Rich S
19. Death Adder 3
20. Drilla Killa 7
21. MORD 2
22. Snakebite 4
23. SYNDOS
26. Orka Mk 4
29. Mega Masher
30. Y4
31. Axe-O-Lotl
32. Obliteration
35. Son of Wedgie
37. P.C.C
39. Chalkie 3G
45. The Axe Attaxe
47. Hell Machine
48. Sheer Hell
49. Flipping Hell
50. Jaws of Hell
52. SOR 4.0 Andy J
53. FP 4.0
54. Wedga Revo 2.0
55. GigaByte 1.5
56. The Nose 3.0
57. GeForce Evo 3.0
58. Psyclonic
60. The Disc 5
LINE UP!!!
HEAT A
HEAT B
HEAT C
HEAT D
HEAT E
HEAT F
HEAT G
HEAT H
HEAT I
HEAT J
HEAT K
HEAT L
Annihilator
The Arena
The Judging System
. I could cancel this competition and leave you the results. Reply if you dont wish this to happen
