Eye Of The Robot - Series 1
Heat I
Round One
Entered by Andrew Jackson, The Nose 3.0!!
Don€™t stick your Nose in! This robot is built with a BioHazard lifting arm, only The Nose is invertible. It moves at 15mph using 2 LEM 130€™s at 36V! The armour is also incredibly thick - 3mm Aluminium, 5mm of Titanium armour - you need to get through that to damage this bot!
Entered by Dave Sheppard, PCC!!
Enter Dave Sheppard, with your first robot! Dave has built a version of Tornado, this is a fast rammer with interchangeable weapons. The armour is tough and has above average pushing power, and it can go at 30mph at full speed, although it can go at 18mph. The weapons include a750 psi flipper, an invertible inverter, a passive scoop, an anti-spinner scoop, a drum, a spinning bar and a set of ramming piercing spikes!
Entered by Alex Holt, Black Panther Queen!!
Let the Queen of the Black Panthers rise to her destiny! A pyramid shaped robot with the point cut off has 4 wheels working on a skid steer system powered by 2 750w motors at 36V. The rear of the robot is sprung down to give smaller ground clearance and more grip, which you need when you have a robot that can go at 24mph! The armour is Aluminium Boron Carbide at 5mm thick, and behind that is 2 inches of Titanium foam. The weapons are a high pressure flipper and an axe!
In Booth #1, Andrew is getting ready to stick his nose in! Dave is in Booth #2, and he€™s praying that with the 750psi flipper, PPC can WIN. And in Booth #3, Alex is going to make sure the Queen of the Panthers will reach its rightful throne.
Roboteers, stand by!!!
3€¦2€¦1€¦activate!!!
The Nose is the first off, having the better acceleration than the other two. Black Panther Queen seems cautious of PPC and its powerful speed. The Nose rams into the side of the Panther, but it€™s skirted and can€™t get underneath. Black Panther Queen turns into the side of The Nose, and does brake the skirting! Once its underneath with the flipper, it clamps with the axe, and flips! The Nose is held up for the crowd to view. Suddenly, PPC batters into the rear of Black Panther Queen, and it does a 360! The Nose is dropped, and pushes into the front of PPC. Back it pushes PPC€¦AND NOW IT FLIES! Whilst The Nose is getting some airtime, Black Panther Queen rams in and clamps onto The Nose€™s underbelly! The bottom panel is full of holes and dents! PCC shoves the sides of Black Panther queen and brakes the skirting, and flips! The Nose isn€™t moving! Andrew is trying to operate the self-righting mechanism, but it€™s not working. Black Panther Queen comes in for one last time, battering the base panel again, as the count begins! But PPC slams in and throws Black Panther queen against the side wall! Will Alex survive?
10€¦9€¦8€¦7€¦6€¦5€¦4€¦3€¦2 €¦1€¦cease!
Black Panther Queen flies out of the arena€¦on €˜cease!€™ meaning Alex survives!
Result:
The Nose 3.0 has his nose bitten off! The chains snapped!
PCC goes through impressively and Black Panther Queen wins by a whisker!
Entered by Matt McDonald, No Close Shave 3!!
Anyone need a razor?! The third version of No Close Shave is an invertible 2 wheel drive hexagon with a pair of Hardox crushing claws on the front with an awesome crushing force. The armour is Vanadium and Titanium, each at 6mm thick. The motors get it up to 13mph!
Entered by Frank Goacher, The Disc 5!!
Enter the most evil and complete robot ever to come out of the mind of a coffee addict! A bell-bar-of-doom shape that everyone hates to love, this robot is HUGE! It has 6 wheels in a triangle formation, to give it stability and effectiveness. The robot moves at 10mph. The weapons on this bad-bot are a he 27kg disc with two teeth, this is connected two a spinning outer axle to warn off attackers!
Entered by Michael Cuomo, Zee Drum!!
Here comes the drum! A box shaped robot with rounded sides, and 8 wheels and strong armour, has the most lethal weapon - a 30kg drum with a top speed of 3000rpm! It moves at 25mph!
Matt€™s in Booth #1 and he€™s waving to the audience. Frank is in Booth #2 and revved up his disc to show the crowd, and they cheer him. Michael is in Booth #3 being cheered by the crowd.
Zee Drum is off first and hits the pit release button instantly! The Disc straight away hits the rear of it, and Zee Drum goes out of the arena! No-one can believe how long that fight lasted, especially Matt as he didn€™t get to do anything!
Result:
Zee Drum is beaten!
No Close Shave 3 and The Disc 5 slice into the next Round!
Round Two line-up
The Disc 5 VS PCC
No Close Shave 3 VS Black Panther Queen
In an unbelievably quick fight, The Disc 5 flicked Zee Drum out of the arena, whilst No Close Shave 3 didn€™t get the chance to do anything!
Dave Sheppard used this robots versatility, speed and control in Round One, using the 750psi flipper to throw The Nose 3.0 over and let Black Panther Queen destroy it from the bottom upwards. It then threw Black Panther Queen out of the arena just after The Nose was deemed dead, so Black Panther Queen went through with it.
Frank is ready in Booth #1 with his Bell-bar-of-doom!! And, using the anti-spinner scoop, Dave is hoping from Booth #2 that PCC can WIN.
PPC is again off the fastest, and actually rams into the front of The Disc 5, which all other robots avoid doing. This is because The Disc€™s front bounces off the anti-spinner scoop, allowing its sides to be rammed and pushed across the arena at the 30mph top speed into the bot shredders, and The Disc bounces upwards, and hits the top of PCC. The damage caused is quite a lot - two scars and the panel is slightly removed. The Disc 5 tries to hit the side, but is unable to. PCC is now on the sides of The Disc, and ramming it towards the pit release button and it hits! The Disc 5 whacks PCC on the side, flipping it 360, but PCC is at its side, and is pushing it towards, and now into the pit!
Result:
The Disc 5 is beaten alive!
PPC pushes into the Heat Final!
In Round One, in the fastest Fan-Fiction fight ever, Zee Drum was battered OOTA in record time, NCS 3 didn€™t even need to do anything!!
A horribly violent Round One saw PCC, Black Panther Queen and The Nose 3.0 tussle - and Black Panther Queen used its axe/flipper combo and the speed and of PCC to bury the hatchet into the workings of The Nose. Black Panther Queen got thrown OOTA during the countdown of The Nose, but survived long enough.
Matt is hungry for carnage in Booth #1. Alex - in Booth #2 - is desperate for a blood-bath on the Black Panther€™s rise to the throne.
Black Panther Queen is much faster than No Close Shave, and shoots out of the starting position faster than a bullet! No Close Shave jousts to get Black Panther into its claws, and succeeds at it! But now, the Panther brings the axe down onto the top of No Close Shave, piercing the armour easily. The drive motors on No Close Shave tried to drive Black Panther Queen backwards, but now it had to let it go! Now Alex pushed down on the controls, driving No Close Shave towards the arena side wall and€¦FLIP!!
Result:
No Close Shave 3 needs in be sharper!
Black Panther Queen wins into the Heat Final!
Heat Final
PCC VS Black Panther Queen
Entered by David Sheppard, PCC!!
The constantly good run of PCC has been the highlight of the heat. PCC has proved that basic can still be tough. The interchangeable weapons, speed and control meant it could beat The Nose 3.0 in Round One, after PPC flipped The Nose, and Black Panther Queen laid into the bottom of it. The Disc 5, famous for being hard to beat, was beaten via a pitting!
The Queen of the Black Panthers started badly when it was nearly seriously flipped by PCC with its flipper, but laid into the underbelly of The Nose 3.0, destroying the electrics. No Close Shave was a much easier victim where it flicked NCS 3 onto the camera tracks.
Dave - in Booth #1 - is only one step away from the semi-finals. Can PCC make it, using the invertible inverter? Alex - in Booth #2 - has only one extra chance to make a semi finalist, can the Black Panther Queen make it?
And they are off! The battle of the little speedsters has begun! PCC bashes into the front of the Queen, and a struggle begins to find the lower front. The sprung rear of Black Panther Queen means that it has the lower blade, and brings the hammer down, once and twice and thrice! On the fourth swing, It gets the axe blade jammed into the workings, and raises the flipper! PCC has now become a robot of ridicule! But Black Panther Queen lets him drop now, and Dave wastes no time in pressing down the forward button! The traction of Black Panther Queen is keeping it from being completely pushed, and slams the axe in once more. Once again, the axe leaves the shell, but the welds on the side panels are broken! PCC is finally around the sides of Black Panther Queen, and slightly brakes the skirting, and lifts it, hoping to flip it. Black Panther Queen is battered into the side railing, and flipped up, but not out of the arena - actually behind PCC! Alex presses forwards, and presses the €˜FLIP!€™ button to send PCC onto the camera tracks! Despite the battering it received in Round One, Alex with Black Panther Queen had won the heat!
Result:
PCC must be made of PVC!!
Black Panther Queen rises to the semi-finals!
Heat I
Round One
Result:
Result:
Zee Drum is beaten!
Round Two line-up
The Disc 5 VS PCC
Result:
Result:
Heat Final
Result:
