Mechanical Noise - Series 2
  • Mechanical Noise - Series 2
    can i enter Envy?
      Obviously, you cant.
        yeah Aaron, I saw that, and I know those numbers are off, but taking off that weight is a jump in a good direction IMO
          Matty and I have decided over MSN that Matty wont have Boxing Clevers stats finished in the near future and that Boxing Clever is to be swapped with one of his bots that I actually have stats for, randomly.
          Faith has decided that Boxing Clever shall be replaced by B2B, which means I currently have all the info I need to kick Heat A and the entire tournament off, which I will do in the very near future by announcing the draw!!!
            Heat A
            Psyclonised (1) vs Terror Gear 3 vs B2B
            Sky Blast vs Panicking vs Cyclone Force 2.5
            Gimme your predictions, gimme your tactics, gimme your thoughts
              Alriiiiiiiiiiiight.
              Psy is going through no matta WHAT. Its the problem deciding between TG3 and B2B, but Im gonna say B2B to survive.
              Sky Blast vs. Panicking vs. Cyclone Force 2.5
              Being realistic...Sky Blast could actually get through here if Panicking decides to go after Cyclone Force. But Im going to say Sky Blast to go out because its way too small and, really, the others will be able to outdo it due to experience.
                CYCLONE FORCES TACTICS
                For the record, the set-up Ill be using for all my battles will be Set-Up 1 unless otherwise stated. Use the speed to my advantage, dodge and attack as and when Im feeling anti-social.
                  Heat A
                  Psyclonised (1) vs Terror Gear 3 vs B2B - I do believe that actually Psyclonised wont get through no problem. I believe it will most likely get through, and will be joined by Matts well armoured flipper that is B2B.
                  Sky Blast vs Panicking vs Cyclone Force 2.5 - Looking at Kodys post, I agree that experience does help, but it doesnt make a robot nessercasily better.
                  Im going to gang-up WITH Cyclone Force on Panicking, if its fine with Chris. My higher speed and ramming force might cause some damage to its aluminium armour.
                  If I get under Panicking or my team-mate, then Ill ram it into the sides and flip it out.
                    8mm Titanium and 7mm Ti/V? Time for a feast!
                    I think all I can do is spin up and hit the first thing in sight. Neither can stand up to the attacks that well really so hopefully Ill be through the first round. Im open to teaming up with either if they are interested...
                    However I feel the champs days will be numbered sooner rather than later.
                      Avoid MOABIE?
                        Id like to offer to team up with Terror Gear.
                        I think if the 2 of us pester the champ enough, we should between us be able to stop him gettign going, and I think if we could get rid of him itd make it a damn sight easier to win than if we had to fight him one on one. So Yes, Im willing to possibly act as fodder in the name of the underdog, hahaha.
                        Any agreement?
                          Sky Blast vs Panicking (me) vs Cyclone Force 2.5
                          Problem is that it doesnt have aluminium armour. One of the main problems Sky Blast will face is its self. At 32mph it will be almost imposible to control. That it also appears to have 2mm ground clearance under the front as it doesnt say it is 0m and the only other given is 2mm at sides, but i will asume it is all the way round. That in mind i will keep my front to it and if it charges at me it should go up the front, so i will activate the forks and lift it up shove it down the pit, thats if it doesnt drive it self down the pit first.
                            Its 0mm at the front Martyn. And I know about the speed and control issues, and I say, Itll help me - you are the slowest in the fight, whichll help you in control, but youll have to catch me first before you can pit me.
                            You may not have aluminium armour, but I seem you read that you instead have Lexan. Even better.
                            (Message edited by paulc on November 30, 2007)
                              doesnt say that in the stats :P lol.
                              Panickings armour is made of the same as the arena walls, and is over 1cm thick, so good luck doing significant damage to it with a flipper....
                                LOL! I had to laugh at that...
