NSIREC2
  • #76
    NSIREC2
    Trojan/Virus/Worm (TVW for short)
    Weight: 100kg
    Shape: Biohazard
    Dimensions: 95cm x 65cm x 25cm
    Drive: 4x S2-400 Magmotors, powered by 6x NiCad battlepacks.
    Speed: 20mph
    Ground Clearance: 0mm all around due to skirts, and 5mm without.
    Colour: Black
    Turning Circle: 0m
    Locomotion: 4 solid rubber wheels mounted internally.
    Armour: The skirts are 3.5mm Hardox, while the body armour is 7mm titanium.
    Weapon: A Hydra-shaped axe, powered by 2x 2kg Co2 tanks feeding Co2 to a 70mm bore 550mm stroke ram, which gives it about 660kgs of force. It has the ability to pierce 3mm titanium, and actually scratch 5mm titanium.
    Srimech: Due to the power of the axe, the robot can easily self-right.
    Notes: Has lots of shockproofing to prevent shock damage.
    Minesweeper
    Weight: 100kg
    Shape: Tornado (S6)
    Colour: Silver, with MINESWEEPER written on the sides in red.
    Dimensions: 90cm x 85cm x 25cm
    Drive: 4x Bosch 750 motors, powered by 5x 36V NiCad Battlepacks.
    Locomotion: 4 Titanium/Vanadium alloy wheels with Vulkanized rubber tyres.
    Armour: 6mm Hardox
    Speed: 16mph
    Ground Clearance: 0mm at front and back due to scoops.
    Turning Circle: 0m
    Weapon: 2 snowplow-like scoops that can move slightly vertically, so I get good pushing power, but 0mm ground clearance at front and back.
    Srimech: Invertible
    Roveress
    Weight: 100kg
    Shape: Growler, with a pink bow on top of his head.
    Colour: Brown, with black and white splotches in some places.
    Dimensions: 100cm x 70cm x 40cm
    Drive: 4x S28-400 Magmotors, powered by 5x NiCad Battlepacks.
    Locomotion: 4 foam filled wheels.
    Armour: 7mm Titanium/Vanadium alloy.
    Speed: 20mph
    Ground Clearance: 0mm at front, and 9mm everywhere else.
    Turning Circle: 0m
    Weapon: The bottom Jaw Is fixed to the ground, and shaped like a wedge. Once a robot is stuck on the wedge, which has Mute-style barbs on it, the top Jaw, powered by a 2kg 1000psi Nitrogen tank, comes down with over 5 tonnes of force.
    Srimech: A lifting arm, built into the back of the robot, powered by a Bosch drill motor.
    Cyrilium Mach 3
    Weight: 100kg
    Shape: Mortis (S4)
    Colour: Gold
    Dimensions: 100cm x 70cm x 30cm
    Drive: 4x S28-400 Magmotors, powered by 5x 24V NiCad Battlepacks.
    Armour: 5mm Hardox
    Speed: 21mph
    Ground Clearance: 0mm at front, and 5mm everywhere else.
    Turning Circle: 0m
    Weapon 1: A diamond tipped pneumatic axe, powered by a 220psi 2kg C02 tank. it can poke holes in 3mm Titanium, and actually scratch 5mm titanium.
    Weapon 2: A flipping arm, powered by another 2kg C02 tank at 750psi. It can lift up to 500kg.
    Srimech: The flipping arm.
    Side Swipe
    Weight: 110kg
    Shape: Barberous 2 with tracks
    Colour: Silver
    Dimensions: 40cm x 90cm x 40cm
    Drive: 2x TWM3R Team Whyachi gearboxes connected to 2x C40-300 Magmotors, powered by 6x NiCad Battlepacks.
    Locomotion: 60cm x 10cm x 40cm titanium tank tracks.
    Armour: 8mm Titanium/Vanadium alloy
    Speed: 16mph
    Ground Clearance: 0mm at front due to Sheer Heart Attack 2 style wedge, at sides due to skirts over the tracks. 5mm all around without wedge and skirts.
    Turning Circle:0m
    Weapon 1: the Barberous 2 shaped body spins at 760rpm, powered by an S28-400 Magmotor.
    Weapon 2: A 9kg Terrorhurtz style axehead, for use as a thwackbot weapon.
    Srimech: Invertible
    (Message edited by corsair_lightning on May 15, 200
    • #77
      NSIREC2
      Updating Corsair, Armory, and Tenderizer:
      Corsair
      Weight: 100kg
      Shape: All Torque (Series 2) with a wedge at the front.
      Colour: Gold, with a blck stripe down the middle, and CORSAIR written on the sides.
      Dimensions: 95cm x 70cm x 25cm
      Drive: 4x S28-400 Magmotors powered by 5x NiCad Battlepacks.
      Locomotion: 4 internally mounted fully Vulkanized rubber wheels.
      Speed: 15mph
      Ground Clearance: 0mm at front due to wedge, 5mm at sides and back.
      Turning Circle: 0m
      Armour: 5mm Hardox
      Weapon: a 12mm titanium wedge, mounted on the front.
      Srimech: an pneumatic flipping arm, built into the back of the robot, powered by a 1.5kg C02 tank at 750psi.
      Armory
      Weight: 100kg
      Shape: Big rectangular prism with a wedge at the front.
      Colour: Yellow, with blue on the top and bottom.
      Dimensions: 90cm x 50cm x 30cm
      Drive: 2x S28-400 Magmotors, powered by 5x NiCad Battlepacks.
      Locomotion: 2 externally mounted fully Vulkanized rubber wheels.
      Speed: 20mph
      Ground Clearance: 0mm at front due to wedge, 0mm at sides and back with skirts, 5mm without skirts.
      Turning Circle: 0m
      Weapon: a 20kg Supernova shaped titanium disc with 2 2kg Hardox Hammerheads, powered by an LEM-200.
      Srimech: Invertible
      Tenderizer
      Weight: 100kg
      Shape: Imagine Hells Teeth, with a wedge on the front, and with Thors Hammer.
      Colour: Black
      Dimensions: 100cm x 50cm x 25cm
      Locomotion: 2 Vulkanized rubber wheels at the front, and a caster at the back.
      Speed: 19mph
      Turning Circle: 0m
      Weapon: A Thor style rack and pinion hammer, with a 2kg meat tenderizer for a hammer head,
      powered by a 2kg C02 tank at 200psi, It can come down with about 1000kg of force, and easily pierce 5mm titanium.
      Srimech: The axe can easily self-right the robot.
      • #78
        NSIREC2
        No it cant
        • #79
          NSIREC2
          Shape: Biohazard
          Weight: 100kg
          Speed: 20mph
          Colour: Black
          Turning Circle: 0m
          Power: 4x S28-400 Magmotors, powered by 6x NiCad Battlepacks.
          Lower the armour grade for the skirts.
          quote:
          Minesweeper
          Weight: 100kg
          Shape: Tornado (S6)
          Armour: 6mm Hardox
          Speed: 16mph
          Turning Circle: 0m
          Srimech: Invertible
          Side ground clearance, and remind me how the scoops move vertically again.
          quote:
          Roveress
          Weight: 100kg
          Speed: 20mph
          Turning Circle: 0m
          Overweight. Thin the armour or ditch the arm.
          quote:
          Cyrilium Mach 3
          Weight: 100kg
          Shape: Mortis (S4)
          Colour: Gold
          Armour: 5mm Hardox
          Speed: 21mph
          Turning Circle: 0m
          Overweight.
          quote:
          Side Swipe
          Weight: 110kg
          Colour: Silver
          Speed: 16mph
          Turning Circle:0m
          Srimech: Invertible
          Overweight.
          Seriously, your bots need a diet plan. Now do something about it.
          Oh, and this is the only time Im going to be helping you. Place one toe out of line and I WILL blow up. Not literally of course.
          EDIT: And how EXACTLY did you modify the previous three? Nothing has changed. :P
          (Message edited by kodster on May 15, 200
          • #80
            NSIREC2
            Thank you for helping me, Kody.
            I am very sorry for all the times I have ignored you, angered you, and yelled at you.
            • #81
              NSIREC2
              Dont arse-kiss: do something about your stats, like actually changing them instead of leaving them the same and saying you changed them. :P
              • #82
                NSIREC2
                If your vapours ere sorted out Mark I might un-ban you from my tourneys
                • #83
                  NSIREC2
                  Mark, didnt you say that you were sorry before?
                  (Message edited by joeychevron on May 15, 200
                  • #84
                    NSIREC2
                    He did, hes just buttering up now.
                    ffffff>And I can say arse. Just like I can say ass. Its no swear word. (LISTENING, KANE? ARSE IS NO SWEAR WORD.) :P
                    • #85
                      NSIREC2
                      Shape: Biohazard
                      Weight: 100kg
                      Speed: 20mph
                      Colour: Black
                      Turning Circle: 0m
                      Armour: The skirts are 4mm titanium, while the body armour is 5mm Hardox.
                      Minesweeper
                      Weight: 100kg
                      Shape: Tornado (S6)
                      Armour: 6mm Hardox
                      Speed: 16mph
                      Ground Clearance: 0mm at front and back due to scoops, and 5mm at sides.
                      Turning Circle: 0m
                      Weapon: 2 snowplow-like scoops that can move slightly vertically, like Behemoths, so I get good pushing power, but 0mm ground clearance at front and back.
                      Srimech: Invertible
                      Roveress
                      Weight: 100kg
                      Armour: 6mm Titanium/Vanadium alloy.
                      Speed: 20mph
                      Turning Circle: 0m
                      Cyrilium Mach 3
                      Weight: 100kg
                      Shape: Mortis (S4)
                      Colour: Gold
                      Armour: 5mm Hardox
                      Speed: 21mph
                      Turning Circle: 0m
                      Weapon 2: A flipping arm, powered by a 1.5kg C02 tank at 750psi. It can lift up to 250kg.
                      Side Swipe
                      Weight: 110kg
                      Colour: Silver
                      Dimensions: 39cm x 90cm x 39cm
                      Locomotion: 59cm x 10cm x 39cm titanium tank tracks.
                      Speed: 16mph
                      Turning Circle: 0m
                      Weapon 2: An 8kg Terrorhurtz style axehead, for use as a thwackbot weapon.
                      Srimech: Invertible
                      If you have any suggestions to make my robots lighter without reducing their quality, I would like them.
                      I replaced the LEM-200s on Armory with S28-400s.
                      I also decreased the damage potential on Tenderizer.
                      • #86
                        NSIREC2
                        And removed one millimetre of armour from Side Swipe...
                        • #87
                          NSIREC2
                          And decreased the size of the tracks a tiny bit...
                          and lowered the weight of the axehead to 8kg..
                          and removed 2mm of armour from Roveress...
                          and decreased the power of Cyriliums flipping arm...
                          and decreased the weight of the Co2 bottle powering it...
                          and changed TVWs skirts from 3.5mm Hardox to 4mm titanium.
                          • #88
                            NSIREC2
                            ..and increased TVWs armour from 7mm titanium to 5mm Hardox making it overweight...
                            ...and did hardly anything about Side Swipe...
                            Want me to go on? :P
                            • #89
                              NSIREC2
                              Sadly you didnt write...
                              And I decided to leave the forum...
                              • #90
                                NSIREC2
                                Kody, are there any problems with my bots?
                                And here is the New TVW:
                                Shape: Biohazard
                                Weight: 100kg
                                Speed: 20mph
                                Colour: Black
                                Turning Circle: 0m
                                Armour: The skirts are 4mm titanium, while the body armour is 6mm titanium.
                                Does anyone have any suggestions for improving Side Swipe?
