NSIREC2
Okay Ill enter my 2 vapourbots and 2 real ones.
Shape: Low box with front wedge.
Colour: Gold, skirts are silver, flipper is black.
Speed: 13mph
Armour: 5.5mm Hardox, and 5mm Titanium skirts. 8mm polycarbonate for the top and the underbelly
Drive: 2 LEM130s, 36 volts
Power: 6 NiCad Battlepacks, 36 volts
Motivation: 4 wheels, Vulkalon rubber on them
Ground Clearance: Wedge - 0mm. 6mm for the rest, but the skirts make it 0mm.
Dimensions: 80cm x 60cm x 20cm
Weapons: Rear-hinged low-pressure flipper, powered by 2 2kg CO2 tanks and a single pneumatic ram. Can flip 250kg and fires about 30-35 times in a fight. Can right it too.
Srimech: It runs upside down, or inverted.
Strengths: A really good all-rounder.
Weaknesses: First-time rookie: top and bottom armour vulnerable.
Shape: Very low invertible box.
Colour: Body cyan, skirts light green, disc white with grey teeth.
Speed: 12mph
Weight: 100kg
Armour: 7mm titanium, 5mm titanium skirts
Drive: 2 S28-400 MagMotors running on 24 volts
Power: 4 NiCad Battlepacks running on 24 volts
Motivation: 2 wheel drive, Vulkalon rubber on the wheels for traction
Ground Clearance: 5mm under side and rear skirts.
Turning Circle: 0
Dimensions: 105cm x 70cm x 10cm
Weapons: Horizontal disc running on 2 S28-400 MagMotors on 24v. The disc is made of hardox, has a diameter of 60cm and weighs 17.5kg. The two 15cm long teeth are also made of hardox and weigh 2.25kg each, so the entire disc weighs 22kg, and thanks to that KE calculator, it produces 97.64kJ. Has a spin-up time of about 4.5 seconds.
Srimech: Invertible.
Strengths: Destructive weapon, good all-rounder otherwise.
Weaknesses: Tires can be hit by axes and crushers, high spin-up time for disc.
Real ones:
Razer (S6)
Typhoon 2 (S7)
Turbulence (most recent)
Tornado (S7)
Dantomkia (most recent)
Hexadecimator (RoboGames 2006)
Speed: 13mph
Speed: 12mph
Weight: 100kg
Turning Circle: 0
Real ones:
Razer (S6)
Typhoon 2 (S7)
Tornado (S7)
