The Crash & Burn Tournament 2
  • #91
    OK it can lift 200kgs and it can toss 120kgs and I meant CMs not MMS.
    • #92
      Someone correct me if Im wrong, but I dont think canisters affect flipping power, just how many flips you have.
      • #93
        OK I have about 50 flips and can I have Typhoon 2 and Drillzilla instead of the 2 already taken please.
        • #94
          Timmy if you ment cm insted of MM then your robot is 1.8mMETERS X 80cm X 2.1METERS. Which anyone can correct me if i am wrong seams a little bit huge for a robot
          • #95
            And Chaos 2 and Gravity have 2 totaly different flipper systems.
            • #96
              Oh and Kody, you do need batteries for a flipper. The valves dont work otherwise.
              • #97
                Oh my god...
                Here we go again...
                • #98
                  Okay, people, just ignore Tim. Well continue like nothing happened.
                  N33D B0T5 PLZ. THX.
                  • #99
                    For the sake of you writing a battle with a vapourbot powered by darkfusion batteries, my entries will be in some time over the weekend. Is there any chance someone can provide a list of real robots entered so far please? Im too lazy.
                    3x 36v batteries arent needed for a flipper mechanism IMO, but correct me if Im wrong. Darkfusion batteries? Again correct me if Im wrong but Im pretty sure they dont exist. Just reference SLA/NiCad/NiMH and get it over with. For the rest see what everyone else said. And stop randomly guessing values for your system - if you havent calculated the true force of the system then dont state it! The flipper has gone from flipping 100kgs to 120kgs to 200kgs with very little change from what I can see.
                    At least hes trying this time...
                    • The Crash & Burn Tournament 2
                      No it can lift 200kgs and it can toss 120kgs and the batteries are NiCad batteries then and the flippers front hinged is what I meant. Its now 80cmX80cmX1.2m. Is that alright.
                        I will get you stats when I find them in my virusfull computer .
                        What real robot(s) have i entered and how many more entries do i need??
                          Erhem, real robots that have been taken are...
                          Disc-O-Inferno [Extreme 1] (Christopher)
                          Big Nipper [S7] (Dave)
                          Storm 2 [S7] (Dave)
                          X-Terminator [S7] (Dave)
                          Kan-Opener [S7] (Dave)
                          Chaos 2 [Extreme 2] (Steve)
                          Spawn Again [S7] (Anthony)
                          Wheely Big Cheese [S5] (Alex)
                          Megabyte (Aaron)
                          Warrior SKF (Aaron)
                          Turbulence (Frank)
                          Tough as Nails (Martijn)
                          Terrorhurtz [S6] (Martyn)
                          Panic Attack [Extreme 2] (Martyn)
                            NAME- Mousey 4
                            SHAPE- Shaped like a mouse with a sort of like front wedge, formed by what would be the mouse€™s face/nose
                            COLOR- blue, well the fur is, the armour is silver.
                            WEIGHT- 100kg
                            SPEED- 13mph
                            TURNING CIRCLE- 0mm
                            GROUND CLEARANCE- 0mm at the front 6mm for the rest
                            ARMOUR- 5mm grade 5 titanium over that is 3mm fur, which extends over the back to form a tail
                            WHEELS- 4 inner wheels, like those on storm 2
                            POWER- s28-400 on 24volts
                            WEAPONS- flipper on the wedge which self rights the robot
                            NOTES- covered in blue fur and has two fire storm style flippers to get it off the wall if flipped on wall
                            STRENGTHS- good armour under fur, fur can jam discs
                            WEAKNESSES- Limited CO2, it€™s a mouse
                            Shape: Low Wedge with small rear wedge
                            Motivation: it now uses four storm 2 style Vulcalon wheels
                            Speed: 12.5 Mph
                            Weight: 100kg
                            Height: 300mm to top of body, 600mm to the top of the disc
                            Length: 1300mm
                            Width: 600mm
                            Weapon: 500mm Vert. flywheel @ 3000rpm. Has a 4.00 second spin up time due to the C40-500 Magmotor on 36v with a 2:1 twin tension cog belt reduction. The flywheel produces 31.5Kj€™s at maximum RPM but is lethal at around 1 second. The second weapon is also the srimech, this weapon is a low pressure pneumatic flipper running on 10Bar (145psi) running into a single 80mm bore ram. This produces 509kg at the ram and is then transferred into the flipper with a leverage point ratio of 1:1. This is a forward facing flipper like FireStorm and will have no problem toppling the heaviest of robots.
                            Chassis: 4mm Grade 5 Titanium monocoque with extra 5mm Titanium ribs to give it more rigidity.
                            Drive: 2 x S28-400 Magmotors @ 36v with a 10:1 Mod 2 spur gear reduction
                            Batteries: 90 x 3000mAh NiCD cells producing 36v @ 9amp
                            Color- the robot and skirts and flipper are blue and the disc is yellow
                            Clearance- it has 0mm at the front due to the wedge it has 0mm at the sides due to skirts its 6mm with out it also has a 0mm at the rear due to the small wedge which is there to replace the problem of the skirt being flipped into the disc. The skirts are NOT hinged and held down by torsion-springs so they shouldn€™t spring up and the rear one shouldn€™t go up into the disc
                            Notes- The flywheel is at the back off the robot it goes over the back of the wedge so if I can get a robot up the wedge far enough it will be hit by the disc. The skirts stop the robot landing on its side.
                            NAME- The deer (was crusher chaos)
                            SHAPE- Invertible box
                            COLOR- the robot and claws are a dark green color
                            WEIGHT- 100kg
                            DIMENSIONS- 1m x 80cm x 25cm (l,w,h)
                            SPEED- 15mph
                            TURNING CIRCLE- 0mm
                            GROUND CLEARANCE- It has 6mm at the front due to the claws and has 0mm at the sides and rear due to the skirts, without skirts 6mm. The skirts also work both ways up.
                            ARMOUR- 3.6mm hardox
                            MOVEMENT- 4 inner wheels that make the robot invertible
                            POWER- 2 x S28 Magmotors on 24v.
                            WEAPONS- it has a front pair of horizontal hydraulic crushing claws set up like deers antlers (shaped like those you find in extreme destruction.) The claws have 3.5 tones of crushing force on the front tips of the claws at the middle is 6tones and right at the back it has 8 tones of crush. The claws are powered by hydraulics through a 120mm bore rams at 3000psi
                            NOTES- invertible, wide base means the deer wont topple while crushing
                            STRENGTHS- Very powerful weapon
                            WEAKNESSES- it could be turned into venison
                            NAME- Star 69
                            SHAPE- It€™s a shaped like a five point star but the points are mounted round a inner circle so the points of the star spin round
                            COLOR- yellow
                            WEIGHT- 100kg
                            SPEED- 19mph
                            TURNING CIRCLE- 0mm
                            GROUND CLEARANCE- about 9mm but is lower under the bottom teeth where it is about 3-4mm
                            ARMOUR- it has 4mm grade 5 titanium
                            MOVEMENT- it uses 6 inner storm 2 wheels
                            DRIVE- it uses 2 x lem 130€™s
                            BATTERIES- 4 x 30 cell 36volt 3ah Sanyo NiCad packs
                            WEAPONS- as I said it has an outer spinning ring so is a fbs the ring is powered by a C40-500 Magmotor, the points on the star each have sharpened teeth on them and it spins in a clockwise direction, each point has 3 teeth on it, one on the bottom for tearing at skirts in wheels, one in the middle for body work and that, and one at the top for aerials and tall robots.
                            SRIMECH- Invertible, points and blades stop it from sticking on side
                            NOTES- according to frank the name is rude, first star shaped robot
                            STRENGTHS- Powerful weapon and drive
                            WEAKNESSES- people not wanting to call it back?
                            Name- Panicking
                            SHAPE- Low invertible box
                            COLOUR- Yellow except for the lifting forks which are black
                            WEIGHT- 98kg
                            DIMENSIONS- 65cm x 60cm x 15cm (Length x Width x Height)
                            SPEED- 23mph
                            TURNING CIRCLE- 0 mm
                            GROUND CLEARANCE- 0 mm at front due to forks, 0 mm at sides and rear due to skirts 7 mm with out, the skirts are hinged so flop over when the robot is flipped
                            ARMOUR- 12mm polycarbonate
                            MOVEMENT- panic now uses 6 Vulcalon wheels to give extra pushing power
                            POWER- 2 x LEM130€™s on 36 volts
                            WEAPONS- on the front the robot has a pair of invertible lifting forks, the forks are sort of like those on panic attack, the forks are powered by 2 linear actuators
                            STRENGTHS- Low ground clearance
                            WEAKNESSES- previously lost to spinners!
                            NAME- Rammy Mk 3
                            SHAPE- Invertible box with front hinged wedge
                            COLOUR- Blue
                            WEIGHT- 94kg
                            SPEED- 20mph
                            TURNING CIRCLE- 0mm
                            GROUND CLEARANCE- 0mm at the front due to wedge this is both ways, 0mm at sides and rear due to skirts 8mm without, the skirts can be taken off if they aren€™t needed for the fight
                            ARMOUR- 4mm Hardox
                            MOVEMENT- it has 6 inner vulcalon wheels
                            POWER- it uses 2 x lem 130€™s
                            WEAPONS- The front wedge can lift up and down powered by a linear actuator, this is only used if the opponent is winning to help get aggression points from the judges. The wedge is hinged so works both ways up however the lifter isn€™t as affective when the robot is flipped though it still works
                            SRIMECH- Invertible
                            NOTES- Rammy finally comes to the fra after entering frw 8 and some arc tourneys
                            STRENGTHS- Compact in size, great pushing power
                            WEAKNESSES- Comparatively Light
                            have fun with that plus my 2 real robots
                              Thanks Martyn!
                                What about my real robots?
