The Crash & Burn Tournament 2
Spawn Again vs. Son of Wedgie vs. A Night at the Bar
destroy Spawn Again, celebrate, yay
?): Mousey 4! It€™s, of course, shaped like a mouse, but with a front wedge where the face would be. On that wedge is a CO2-powered flipper and two front-hinged flippers on the sides to get it off of walls. Its S28-400 provide ample power enough to give it a 13mph top speed, and it has 5mm G5 titanium under the blue fur (3mm) that is used to clog disc and blade axles. It has a ground clearance of 6mm at the sides and rear though, so it can be flipped. Will the Mousey be squashed?
Crash flies into the air, but not quite over the wall, tilting off the railing and...stacked up against the wall. Mousey meanwhile has driven right into Tails and stopping the blade got under and FLIP! Tails is inverted! However, it rights itself using the front flipper. Mousey is right there, though, and (FLIP!) tosses it right back over into an empty CPZ! Tails rights itself can before Mousey can attack again, and is desperation turns to use the srimech as its weapon...and it works. FLIP! Mousey is inverted, but falls onto its side! It also rights itself, and decides to attack Tails again, but notices the blade back up to speed and pointing right at him, so he now reverses gears going after Crash in the CPZ. Ancalagon€™s jaws open, and he€™s now got Crash, whose side has been gashed up badly by that earlier disc hit, in the jaws. Obelix hammers Crash again. BANG! The top panel is caving in! Mousey bursts in from nowhere and getting under an occupied Obelix tries to flip it...no luck. Tails hammers Mousey in the rear.
Ancalagon however has released Crash...who isn€™t able to move! Mousey gets lout from under Obelix, and goes for Crash. Obelix turns to him and brings down the hammer but misses (CLANG!), and (FLIP!) Mousey tosses Crash against the wall and stacks him. Chris hangs his head, the controls aren€™t working at all, and Steve lays off, knowing that Crash is dead, and Mousey saves him the trouble by giving it a flight over the fence courtesy of the flipper. FLIP!
) and spins at 2000rpm, giving out 55kJ of force upon impact. The upper part of Bar is 4.5mm hardox, and the lower part is 5mm hardox to balance the weight. If flipped, the bar will stop spinning to prevent it from hitting the floor. S28-400s power the drive to 15mph, but it looks very unstable, and as Martijn puts it, a €˜rocking chair on steroids€™.
