The Crash & Burn Tournament 2
WHAT A SHOCK! Anyway, my predictions
Round 2
Knightrous Wedge vs. Panicking: To be honest, this fight could go either way, but its mostly going towards Panicking.
Metal Sonic Spin Dash vs. Cosmic Thunder 2: If Steven gets around the sides, he could win, but the faster, lower wedge of Alex M is going to win it here.
HEAT FINAL: PANICKING vs. COSMIC THUNDER 2
From those choices, Im going to go for the highly underrated COSMIC THUNDER 2 to make the series semis.
Round 2
OHHHHH!!! Panicking is seperated about 25 feet from his right middle wheel! Knightrous Wedge flies in again, seeing an opportunity, and tries to get the lifter under that fully exposed wheel hole, but Taki lets Panicking down. Aaron lowers his own flipping arm and slides underneath the side, tossing Panicking further into the CPZ! (FLIP!) Tira sidles back, blade back at speed, as Martyn is beginning to panic himself. None too keen on letting the house bots have some more fun though is Aaron, and his wedgebot flicks Panicking right up against the wall! (FLIP!) Panicking however comes down, right side up, and his forks are pointing right at Knightrous Wedges side! Martyn jumps at this, and before Aaron can even blink the forks lift up his bot and hold it high into the air! Its just too bad that Tira had to barge in again.
