ENVY
  • ENVY
    good old HPC :P
    • ENVY
      i have asked to hollow out to half the width of the gear and 15mm from the teeth. i dont think they will bend at that. well i hope not.
      • ENVY
        Looking at this the new Envy is going to be mega fast. Boschs on 36V 5.7:1, wow. Have you actually calculated the speed of it
        • ENVY
          sorry ed but i have changed to mag c40 motors and i will run them on 24v for realibility. so 4000 ish rpm at 5.7/1 wil give on paper 17.7mph which makes it 1mph slower than at uk champs.
          • ENVY
            8 inch diameter wheels ...
            Torque (per motor) to spin wheels 1111.5 oz-in
            Amps (per motor) to spin wheels 138.08 Amps
            Theoretical Top Speed 16.825 MPH
            Total Peak Amps 276.16 Amps
            Amp Hours Required - 3 Min 9.6659 AH
            Amp Hours Required - 5 Min 16.109 AH
            • ENVY
              no wonder his hawkers were going flat after each fight down in portsmouth !!! :sad:
              • ENVY
                there may be trouble aheeeeeeeaaaaaaddddd. but while theres sunshine and music and laughter and romance......lets face the music and dance.
                will be using 4 bot packs at notts and jason will be using 4 13ah hawkers so which ever turns out the better we will see. and yes the title of the oracle is between woody and john reid.
                • ENVY
                  jeeez u guys use a lot of power...
                  Gravity 3 could easily fight 2 full battles with only 3 9Ah 12V pbq batteries... 20 to 1 on 10 go cart wheels.
                  Was this due to excellent regen braking in the speedcontrollers ?
                  • ENVY
                    John has a far better understanding of the math involved in Robot building than Ill ever have!
                    • ENVY
                      Heres your specs W.J.
                      Same C40 motors ... @ 24v
                      Torque (per motor) to spin wheels 396 oz-in
                      Amps (per motor) to spin wheels 49.192 Amps
                      Theoretical Top Speed 5.9940 MPH
                      Total Peak Amps 98.385 Amps
                      Amp Hours Required - 3 Min 3.4434 AH
                      Amp Hours Required - 5 Min 5.7391 AH
                      @ 36v
                      Theoretical Top Speed 8.9910 MPH
                      (Message edited by woody on October 25, 2007)
                      • ENVY
                        gravity didnt speed for the weapon to work at its best. i need speed for envy to work at its best. notts will tell the tale.
                        • ENVY
                          Woody, C40 motor = Bosch 750 24V ?
                          And indeed Shane, just a little tip of the flipper, about 1 inch was enough for flipping action...
                          • ENVY
                            where can I find some more info on Envy by the way
                            • ENVY
                              i dont have a web site but you can mail me with lots of questions and i will be more than willing to answer them.
                              • ENVY
                                Close W.J.
                                Higher stall Amperage with the C40.
                                C40
                                Torque Constant oz-in/amp 8.06
                                Stall Amperage: 480
                                Voltage Constant: RPM/volt 167.9
                                Operating Voltage: 24v
                                Bosch 750
                                Torque Constant oz-in/amp 8.7
                                Stall Amperage:270
                                Operating Voltage: volts 24v
                                Go figure .
                                http://www.architeuthis-dux.org/torquecalc.asphttp://www.architeuthis-dux.org/torquecalc.asp
                                You didnt think I came up with the figures myself!
