Hmm, Coilgun powersource?
300A VESC in the works, feature suggestions wanted
So the PCBs are finished and 40 are heading back to me now. Should arrive on Monday. Currently the first board is being assembled and tested to ensure everything is OK before building the rest.
Heatsinks have been waterjet, drilled, tapped and countersunk. Ready for bead blasting and anodizing hard black.
I also got a load of custom length spacers made to reduce the thickness of the thermal interface between the copper bars and the heatsink. After some testing with the shorter spacers, the boards now perform much better under high current. When testing with the Revolt 160sh the motor was getting too hot long before the controller.
OK will make one shortly then.
The fab finished the first board and it passes the functional tests I sent them. (Without a motor) Which checks that everything is connected properly and working. So I am pretty confident they will work when I get them back.
Here are the photos, it is so much cleaner than the ones I put together!
