300A VESC in the works, feature suggestions wanted
I now have a Revolt 160 Short for testing (thanks maddox10) and an Etek on the way to use as a generator. Should be able to do some good testing up to 18s 300A and make sure nothing explodes.
Its also a good opportunity to test its ability to drive large DC motors as an alternative to a Vex Victor BB. Which would mean you can switch between brushed and brushless with relative ease.
With the experience in reprogramming smaller brushless ESC's for brushed applications, I forsee a golden future for the Euan 300A VESC.
Some of us like the power of the inefficiënt, but dirt cheap Series Wound motors...
And an ESC controlling a parallel wound motor has only 3 wires... I wonder...
8AWG cables for input and output, with choice of 8mm bullets or lugs.
STM32f405 Cortex M4 microcontroller
6x 100v 1000uF High-Ripple United Chemi-Con Capacitors EKZN101ELL102MM40S (0.017Ohm)
TVS protected 5v rail, suppied from receiver
15-75v rating, 16s LiPo maximum (Rating at 80v (90v maximum) on the current shunt amps, so need a bit of margin to account for ringing/transients
200A (13.4kW@16s) continuous for a few minutes
300A (20kW@16s) burst for a few seconds
All standard VESC® features (CAN, SPI, Encoder/Hall support)
Same amazing VESC® performance with sensorless motors.
Designed specifically for combat use. Absolutely no heavy components on the boards which might fall off with shock.
Each unit is hand built and will be rigorously tested before sale using a range of motors. (100W, 2200w, 5300w, 9800W) If I have the motor you will be using then I can set it up for you before sending it.
Testing status: Current tests:
100A continuous - Works fine.
130A continuous - Works fine.
150A continuous - Works fine.
200A continuous - Motor got too hot after 40s, will try again with Revolt motor.
300A burst - Will try with Revolt motor after connecting to Etek as a generator.
ERPM Tests:
120000ERPM -Works fine.
VESC features:
BLDC - Works fine.
FOC - Works fine.
DC - Etek testing to follow.
I/O:
PPM input - Works fine.
CANBus - Works fine.
ADC input -Works fine.
Motor Tracking:
Sensorless tracking - Works fine.
Hall Sensors - Works fine.
Encoder - Testing to follow.
Motors tested:
Turnigy Rotomax 1.2 (1.9kW) - Works fine.
Turnigy Rotomax 50cc (5.3kW) - Works fine.
Turnigy Rotomax 150cc (9.8kW) - Works fine. Revolt RV160SH 58KV (8/15kW) - Works fine.
Working on a motor-generator pair to do some high power testing, consists of a Revolt RV160SH and an Etek-R. Any ideas what to use as a load on the Etek? Was thinking just a load of enamelled wire in a bucket of water would work.
I use steel fence wire wrapped round a ceramic core in a bucket of water... don't want it too low resistance or most of the heat will be released in the ETEK
Got the motor-generator setup done today so was doing some proper testing! I can safely say its a beast, the LiPos were screaming.
This was after about 30 minutes of absolutely thrashing it. The load was about 9.5kW at 12S. Its quite cool to watch the wire move as the current increases . The beeping is our battery monitor telling us the voltage had dropped below 3.8V from 4.2V...
