Afternoon all. Time for another of my ridiculously generic and open-ended questions.
This is another one of those things which has been discussed before, but to which I suspect the answer has changed over time.
As the long-suffering members of this forum know, Im at the about-to-build stage for a heavyweight (about being at least a couple of paycheques away). Im trying to strike a balance between not spending more money than I need, and being able to re-use bits (so not buying anything completely useless). Robot bits themselves I can budget for, but Im trying to get a feel of what I need in terms of tools.
What, in hindsight, do people find they need most urgently?
As a starting point, you can assume Ive done a little DIY. I have screwdrivers coming out of my ears, some files, hammers (including the sledge variety), clamps, pliers, a cheapish drill, an even cheaper jig saw and a funny mains powered dremel thing with a bendy nose attachment for delicate work (some chance). Oh, plus some electronics stuff (meters, soldering iron, that kind of jazz - if I need a scope Ill come to work).
Even with optimism, I realise this wont get me far. Im presuming Ill be going down the welding route (I know you can screw things together, but I guess you need a heck of a lot of pre-drilled lumps of metal to repair damage in a hurry, where a welder and a sledgehammer can fix quite a lot). Im also presuming Im not going to be buying titanium any time soon, so MIG will do. (Also Ive never welded anything, but theres an obvious remedy for that.)
So... I need a MIG welder (Im told one which really takes gas, which Ill accept). I guess a tap and die set would be handy? Will I need a band saw, or will a jig saw and a lot of patience do me?
I currently dont have a bench drill, and Im guessing thats fairly high on the priority list, yes? (Preferably one which lets me cut grooves? I cant see a plunge router working with metal.) Possibly also a (small) angle grinder?
As an aside, gears/sprockets. Is there any way to manufacture them without paying somewhere to laser cut them? Just should I need something odd. Im guessing the disc of metal and a while with a file approach is a bit hit and miss?
Finally, lathes. They seem to be popular - although B&Q only seem to hold the wooden variety. Whats the difference? Presumably I dont need something more than 1m long, but beyond that? How much will one help me?
Oh, and before anyone says it, I have goggles (the most important bit of safety equipment as I think Norm says, although I doubt he was using oxyacetaline at the time), gloves, mouth guard, fire extingisher - and MIGs seem to come with face shields. I also have a healthy sense of paranoia around power tools.
Im presuming B&Q (or similar) is going to make a few hundred quid out of me at some point, but Id prefer not to make it more than I need. Yes I know a good quality drill will serve me better, for example, but Ill wait for the cheap one to die first. On the other hand, I dont want to spend a week making something only for someone to say oh, you wanted a... which costs a tenner.
Anyone want to advise me which equipment to kill myself with?
Fluppet
Fluppet
