Yes Windscreen Wiper motors
Interms of amount of time lasted I would guess a fair amount! I ran 2x Technobots WW motors for about 15min @24v on 2.2amp SLA batteries. So I would expect about the same from yours if not longer.
k ty. Yeh ww motors are noobish but hey so wat (retorical question).
I plan to use would i connect the speedos in parallel to the batteries so i get 24v going through both?
Is it possible to get a mixer(s) for electronizes that will let 1 receiver output control motors in forward and reverse of two seperate speedos, and another output to make one side go forward and the other backwards so it will turn?
I started out with the Futuba 2ER which Technobots (http://www.technobots.co.ukhttp://www.technobots.co.uk) now sell for just under £40. That includes the receiver and two servos, although you probably wont need the servos. It only has two channels however, so youll need to replace it if you add any weapons that need remote control.
