Hi im making a bot and im using 4 windscreen wiper motors i think or 4 planetary geared motors, who knows. anyways id like to know if a 4qd RC interface would work with electronize speedos to produce a tank steering type robot with 4 low wattage motors.
1st bot
1st bot
ok i know im a complete newbie aswell, but my understanding is that with a 2 channel receiver all you will be able to do is drive it about as each electronize will take up a channel, if you want any weapons or for it to do anything else you will need a 4 channel one.
I hope someone comes along and proves me right
1st bot
A 10A + 5 with 2 motors sharing it. You may be pulling alond the lines of between 10 and 25 amps per motor depending on your drive.
and yes, Andrew is right. You need 1 channel per moving part on your machine. A minimum of 2 for drive and more for any weapons/schrimechs.
I feel like you 2, Ive been with Team MORG b4 and now trying to build a featherweight on my own, it feels like Im starting from scratch... Keep it up both!
1st bot
I know some has probably put this up b4 but it is still the best guide for building a featherweight I can find on the internet.
http://www.stupoo2000.pwp.blueyonder...technical.htm>
1st bot
well, you will want to wire the batteries up in parralell to give 12v but double Amp. Wire both speedos to the same batteries as this will save you alot of weight rather than having two seperate battery packs! The electronize speedos do give forward and reverse control for your motors so there will be no problems in controlling your robot. Are you running 4 gold motors for your drive? i use 2 24v for drive, and a 12v overvolted to 24v on my weapon. i use 3.3Ah NiHm batteries and that gives me enough power for atleast 1 to 2 battles.so that should be fine for you.
1st bot
Id go add up how much that would all weigh before you go much further !
Ed
