1st bot
  • #31
    1st bot
    lol. Does anyone know how i can measure how long a battery would last at a certain wattage and voltage etc.
    • #32
      1st bot
      quote:
      so what weapon are we going to put on it
      May I suggest using a gerbil so that it can gnaw your opponents into submission..... eventually
      Not exactly Chompalot, more like Chewabit
      • #33
        1st bot
        Can someone please tell me how i calculate how long a battery will last
        • #34
          1st bot
          Heres how Id do it.
          Volts= Joules/Coulomb
          Amps= Coulombs/second.
          For a 5 amp hour battery, that would be 5 * 3600 (secs in an hour) = 18000 coloumbs
          at 30 amps 18000 Couloumbs (storage)/ 30 (rate) = 600 secs. Roughly 10 minutes.
          Thats how Id do it anyway. Some1 is now bound to bring in an complex efficiency factor on the battery, but thats the basic physics.
          • #35
            1st bot
            Though its not that easy with the hamster.. .
            You cruel buggers. How can you expect a hamster wheel to spin at a 10:1 gear ratio? Even Im not that cruel to animals!
            On the plus side, It appears to be the energy source of the future. According to Star Trek: The Next Generations engineering panels, a hamster powers the Enterprise Ds warp drive...
            • #36
              1st bot
              i love gerbils
              • #37
                1st bot
                Ok say i was gonna use four windscreen wiper motors what could i expect to get out of them e.g. speed rpm torque and what voltage etc. i need to use. Lets not have a discussion about weight etc.
                • #38
                  1st bot
                  I think they are about 150rpm when ran at 24volts, with a decent amount of torque. You would also need fairly large wheels (minimum of 200mm) and still would be slow.
                  • #39
                    1st bot
                    so basically you wouldnt expect to get much speed out of them but a reasonable amount of torque. How much torque would you expect roughly. Can they be safely run at 24v?
                    • #40
                      1st bot
                      mark you can get some decent speed out of them if you do what i am doing. Ive tore off the gearbox and am using cogs and chains to regear the motor. they can be safely run at 24v.
                      If you send me an email i can give you some pics and more info on what I am up to.
                      • #41
                        1st bot
                        did you get my e-mail gary?
                        • #42
                          1st bot
                          yeah sorry was runnning out the door jst after I posted. reply sent
                          • #43
                            1st bot
                            Right for a 4ch reciever do i need four seperate crytals on four seperate channels?
                            • #44
                              1st bot
                              Nope you only need 1 crystal per receiver.
                              • #45
                                1st bot
                                Could someone give advice on this setup-
                                4 wiper motors at 24v, gearbox removed like gary says, running off 2 12v 5ah batteries in parallel to give 24v. I plan to use 2x 30amp electronize speedos. Could someone say if this would work and maybe battery life i could expect and any other advise (not on weight). I obviously need to put each pair of motors in paralell to get 24v in them?
