Graupner motors
  • Re: Graupner motors
    i couldnt find any car seat actuators on ebay.
    would a gimson spare motor do? http://www.gimsonrobotics.co.uk/HRS550_ ... motor.html
    or should i buy a prebuilt gr01 (the actuators arent exactly on my budget but if i have cash left a GR01 on some M12 threaded rod actuator would be nice and powerful i suppose
      Like the drill motors, I doubt the Gimson motor would fit into that seat actuator. I'd save up for a Gimson ready built actuator TBH, they're powerful and much less hassle.
        do the gimson actuators use GR-01s in them?
        i will only have an actuator if i have money left when its finished.
        it will be more fun.
          u have to search under (seat motor) to get the best results, the more common 1s on ebay are from ford mondeo
          http://www.ebay.co.uk/itm/Ford-mondeo-e ... 500wt_1169
            cheers peter,
            they're not actually 500watt are they?
            that's some powerful lifter.
              i doubt there 500watt but i know they should be able to lift a featherweight because mine can lift 24kg probably a bit more but it starts to straggle at the 24kg mark
                24kg that neerly the weight of a bag of cement!
                if the mechanism is built right it should be able to.lift a human (not very high/fast)
                  Define lifting a human . I am around the 105/110kg mark and a FW size actuator wouldn't lift me regards of the mech.
                  It only needs to lift a FW and they will do that easily. Try and find a video of Mr Happy the FW for a comparison.
                    u only have to get them a few mm off the ground to stop them going anywhere, and mine couldn't lift a human it can hold 1 without breaking
                      here is a cheap actuator if u want 1 just found it on ebay, should lift 75kg on the tip
                      http://www.ebay.co.uk/itm/Linear-actuat ... 500wt_1169
                        If you want a powerful actuator that's going to lift something quickly you could take a look at the Duff Norton ones, we have two one for sale in the 'For Sale' thread
                        viewtopic.php?p=132782#p132782
                        As used in Force X, also curiously the first robot to use (and 'discover') the 35w Bosch Motors - if only I was on commision, the originals in Force X are still going strong (albeit with a brass gear to replace the naff plastic one that will fail)
                          ok a quick kind of update.
                          the stage i am at with the robot is my mum says she will let me have it if I am sure i know everything (pros and cons) of everything.
                          which i am thrilled with as normally the only answer is no.
                          so my set-up will be.
                          escheap85s
                          2/4 drills
                          i need advice on batteries and wheels as my budget isnt huge and i want someting usable in v2 of the bot.
                          6mm polycarb
                          giant cod tx and rx
                          sound good?
                          my mum found a 3/4mm polycarb box that looks great for an antweight. if not i will get some silicon seal and stick my fish in from the pond in the winter
                          also my mum found out at work that one of her workmates friends runs a scrap metal yard. yay
                          so i have found the advantages of the botbitz on that thread but are there anything esle convincing.
                          thanks
                            going to want more than 6mm polycarb
                              id say 6mm is perfectly fine both for base and armour
                                bearing in mind this robot.will be replaced by v2 by the champs
                                so no spinners
