pnneumatic axe robots
  • #31
    Re: pnneumatic axe robots
    Originally posted by Bodge Job
    Hmmm that's a little short for what I want, I was looking for about a 150mm stroke ram....
    I'd say that's a little too large for a feather :P
    • #32
      Originally posted by mattsdragons
      shockwave (LP flipper from team ocean) had about 60kg worth of flip and that could flip a FW oota. and that system didnt even have a buffer tank
      Just to clarify Shockwaves specs as you mentioned earlier. Shockwaves pneumatics have remained unchanged since it became Eric Jr its a 40mm Bore 60mm Stroke ram and the max pressure is 11 bar set by the PRV.
      Just need to get those blasted LED's hidden by the Robo-Coat before the next event
      • #33
        alex, my 30mm bore ram is 100mm stroke and the 80mm bore is 50mm stroke
        • #34
          Ahh, the 30mm bore 100mm stroke ram may work, but I thought u were using it for your fliper?
          • #35
            wait, i have done some more calculations, and that ram would only give me 6.43kg of lifting force, so i need a 50mm bore 100mm stroke ram..
            • #36
              http://www.northerntool.com/shop/tools/ ... uct%20Page
              this may work, but its a shame its from the US... but its still only £30 ($50) including postage...
              and a rack:http://www.beltingonline.com/1-5-mod...teel-rack-6801 and gear:http://www.technobotsonline.com/stee...-38-tooth.html that should give me just over 200 degrees of movement with 18kg of lifting force at the tip of the lifting bit...
              • #37
                I would have thought you would get more lifting force than that from a 40mm bore 10 bar ram
                • #38
                  Yeh, buy with the gear ratio I'm using to get the 200 degrees movement, means I need a lot of power, and 40mm bore cant provide that...
                  • #39
                    I might get just enough if I run my system at 11.5 bar
                    • #40
                      yeah, but i haven't found any rams that work at that pressure...and i'm using quiet a long axe arm, so if you used a shorter one, it could work for you.
                      • #41
                        How long is your axe arm?
                        • #42
                          About 30cm and does any one have any idea what tank i could use for the buffer tank? and it only needs to take 10 bar so i don't peticulaly want to use a normal full pressure tank, because it would be to heavy. thanks
                          • #43
                            i have 3 small dry powder extinguishers that would be suitable. i have 0.8kg, 1kg and 1.36kg
                            • #44
                              do they take 10 bar? and that fittings are they? as one of those may be perfect.
                              • #45
                                they'll take 10 bar easy. no fittings as of yet
