Re: pnneumatic axe robots
The regulator screws on to the pin valve, but the pin valve on the bottle is replaced with a different valve, which has the same thread as the pin valve, and because the reg is designed as an extra, it has also got the thread from a pin valve, but are you saying I could just screw a female 1/2 BSP joint on to the regulator? How well would it fit, would it be air tight? Or if it is slightly to big, could I fix it by running a 1/2 BSP die down it to correct it, or would that be a bad idea?
Originally posted by Hard Time
