i was wondering what solonoid valves people use in axed robots? and how they make the ram with teeth built in (for poxwering the axe) and what sort of presure people use??? thanks...
pnneumatic axe robots
Re: pnneumatic axe robots
Hmm I think the rack and pinion idea is the best for axes, but sadly I don't have the obility to machine a ram with the teeth, and I was just wonderiing, what presure do people use for axes, because all the ones I have seen are low presure...
Oh ok, any peticular reason there neally all low presure? Is it to do with haveing the strength to convert the expansion of the ram to the rotation of the axe? Or is it just to do with the fact, it would just send the robot with the axe flying? And what presure do these robots actuly work at? 10bar? 20bar??? Thanks every one for there help so far!
We have been looking around, and so far have not found the parts to make it FP, but we Have already found al the parts for low presure, and were going for a rack and pinion style linkage, I was wondering about useing a 20mm (ish) nylon 6 body with a 5-10mm HDPE armour do you think this would be storong enough to sport the axe? Thanks
http://i1111.photobucket.com/albums/h46 ... B-orig.jpg my first CAD of the axe robot, although, the axe will be larger, and the dementions will be adjusted to fit the pneumatic
