Re: Using Helium to reduce your weight!
If I remove the drum from boner it weighs around 8 to 9kg and with 22mm nylon bulkheads and a 4mm hardox scoop at the rear, could still cut it with the top spinners and keep running.
A ram bot is easy to make in under 8kg to take on some of the best spinners
