Re: Using Helium to reduce your weight!
No, because that machine would still weigh 30lbs. Stick it on a set of scales with plastic surfaces (negating any magnetic pull, just for clarity) and it would still show 13.6kg. Okay so it would be harder to pull/lift up from the arena floor but that doesn't mean it weighs more (in terms of mass, rather than actual W=mg weight)
I agree with the comments that using magnets is simply making use of the arena environment (steel floor) in the same way as a ground-skimming wedge makes use of the arena environment (flat floor). If something is compromising the enjoyment or competitiveness of the sport, then by all means alter the arena environment to hinder it*
But I sincerely hope the rules aren't re-written to banish magnets; too often in this spobby rules have been re-written because someone has exploited a loop-hole (perhaps abroad more so than here), usually in ingenious ways. But rather than applaud and admire their ingenuity, the loop-hole is closed because there were murmers of unfair advantage.
*For example, the discussions about having an uneven surface to discourage wedges. However steel floors are still relatively new and presently only feature at Robo Challenge events, so not only has the utilisation of magnets been impossible until recently, but they can only be used at one or two events per year.
surely that machine would breach the 30 pound weight limit as stipulated in the rules
