help with Gianitcod 2.4ghz 4-Channel Mode2 Transmitter neede
    Re: help with Gianitcod 2.4ghz 4-Channel Mode2 Transmitter n
    as far as i know the r7eh is the same as the r6eh in terms of compatibility but it has an extra channel and has the connections on the side. you should plug the connectors that come from your esc's into channel 1 and 2 on your receiver. it doesn't matter which ones in channel 1 and which ones in channel 2 as the servo reversing function can be used to correct this. the throttle channel is for the weapon (if you have one).
      i have done that but i still get nothing from it
        Do you have a servo and a receiver battery to hook up to the receiver outside the robot? That way you can at least determine if the receiver is responding to the transmitter and takes out as many variables as possible.
          i dont have a servo too hock up too it which is a shame.
          i will post some pics soon of my set up too see if anyone can give me any help over it
            here are some phots (forgive my bad photography skills)
            http://s568.photobucket.com/albums/ss12 ... e003-1.jpg
            http://s568.photobucket.com/albums/ss12 ... e002-1.jpg
            http://s568.photobucket.com/albums/ss12 ... e004-1.jpg
            also, my rc stuff didnt come with crystals and i was wondering if i need too get some?
              no its 2.4ghz
                No crystals needed.
                Your pics are a little blurred and I cannot see a receiver power supply / 4.8v battery pack or BEC.
                The Electronize FR15HVR and FR15TVR have a battery eliminator circuit (B.E.C.) providing a regulated 5 volt supply for the receiver and servo's... I don't think that the FR30HX has.
                This possible lack of a 4.8v power supply to your receiver and thus your ESC's ( the internal electronics of the Electronize requires 4.8v / 5v to function and the internal electronics turns the higher voltage battery supply to the motor on and off ) and would explain your prob.
                http://www.howesmodels.co.uk/Railways/v ... bCatID=132
                BEC ...one of many makes... http://www.dimensionengineering.com/Par ... 4Qod_CNBIQ
                Cheers Woody
                http://www.dimensionengineering.com/BECFAQ.htm
                • #23
                  i am using 1 FR15HX and one FR15HVR so (as far as i was told) the addition of a 4.8v battery is not needed
                  • #24
                    OK
                    Can you tell us what you has been done with the twisted orange and red wires from the FR15HVR.
                    • #25
                      its currently not in use but is still connected because tbh, im not too sure what too do with it
                      • #26
                        NP
                        Here's a pic ...
                        NOTE :- I've shown the signal wire in yellow in your case it is WHITE[attachment=0:2r42jcgu]FR15HX.JPG[/attachment:2r42jcgu]
                        Quick edit to pic....
                        • #27
                          Make any sense Matt?
                          • #28
                            how can i use 2 batteries for this?
                            my design uses 2
                            • #29
                              my design uses 2
                              I've got an awful feeling that you might want to use one bat per controller.
                              My advice is DON'T ...simply wire up your bats in parallel[attachment=1:24ki7vmk]FR15HX2.JPG[/attachment:24ki7vmk]
                              Series config ...double the voltage.
                              [attachment=0:24ki7vmk]FR15HXseries.JPG[/attachment:24ki7vmk]
                              • #30
                                i have connected it up in the first diagram way but im still getting nothing.
                                i know its a big ask but is anyone im the leicester area willing too let me bring my bot round so i can get someone wih more knowledge than me too have a look?
