Re: help with Gianitcod 2.4ghz 4-Channel Mode2 Transmitter n
as far as i know the r7eh is the same as the r6eh in terms of compatibility but it has an extra channel and has the connections on the side. you should plug the connectors that come from your esc's into channel 1 and 2 on your receiver. it doesn't matter which ones in channel 1 and which ones in channel 2 as the servo reversing function can be used to correct this. the throttle channel is for the weapon (if you have one).
