Re: From The Ground Up (Advice Thread)
depends what you are going to use the steel for ali is good as a replacement aswell????????
you can use thicker foam aswell to shock absorb and its lighter
Kevlar as far as im aware has never been used in modern robots and i believe its Pricey++++++++ stick to well know materials, polyc, hdpe, nylon, steel, ali, ti and not forgetting the ultimate WOOD!!!!!!!!!!!!
(block of wood = champion)
alex
alex
