Re: From The Ground Up (Advice Thread)
An angle grinder is your best bet for cutting metal - they're not that expensive, get one, you'll find yourself using it a fair bit. Saves you a LOT of time, and there are materials you'll want to use at some point which really can't be done any other way without something like plasma/oxy-gas/waterjet/laser/whatever, like hardox.
As for drills - any decent HSS bit will do it, make sure to use a center punch and WD-40 or whatever as cutting fluid. You don't need to mess about with cobalt drills or anything until you're working with pretty high grade alloys.
