Re: Starting Point
Looks like a nice start to a build.
If you ask Kane nicely, I'm sure he'll happily move this to another section of the forum. Or better yet, don't hesitate to start up a build thread for it, that way you could keep all these pages of research seperate from the building of your machine.
For an axe, I've seen a couple in B&Q that are quite similar to what Avenger uses. They have a fibreglass handle too so won't risk splitting as mentioned in the electric axe guide page. They may be a bit short though, depending on the design of your robot body.
Alternatively, you could make your own, maybe with a bit of steel box section as an arm and a shaped piece of Hardox or something to make the axe head.
Actually just remembered seeing something a while back that I thought would make a good robot axe. Ice axes used in climbing. They had a funky shape to them and the handle was metal (with some plastic coating over it) so would be sturdy enough bolt to. Their strength in general should be good as they have to support people dangling from them. I think they can be quite expensive though.
I may be about to contradict myself here actually. Found a pic of what I was thinking of:
http://gearflogger.typepad.com/photos/u ... sanano.jpg
Not sure how well the axe head/attachment would hold up. Might be fine for axe hits, but copping a blow from a horizontal spinner could be damaging. Plus that one is £85 :shock:
