Re: Starting Point
For the voltage problem, 28.8V is the nominal voltage of having four 7.2V packs connected up (1.2V per individual cell). When a battery cell is freshly charged though, it can be up to 1.5V so multiplying that by 24 (total number of cells in four 7.2V packs) gives 36V. Even if they only charge to 1.4V each, that's still 33.6V so the chance is that it is too much for the controller.
I assume it goes back to working again if you revert to 21.6V after trying the 28.8V setup? If so, then the controller's probably got an excessive voltage cut-out circuit in it to protect the unit.
