Featherweight Database
  • Featherweight Database
    robot name: Kang
    Power: 1x 12v cp2400scr nicad pack and 2x resoldered 12v drill packs
    Drive: 2x 12v Drill Motors/gearboxes at 12v with 125mm wheels and a hub made from the guts of a drill chuck.
    Controller: two 12amp custom made drill trigger servo controllers.
    Weapon: 240mm saws, either 72 tooth or 50 tooth version powered by an ev warrior size motor at 24v (has a flat plate on it). speed is about 5000rpm ~
    Armour: 10mm 5083 aluminium lid with 4mm steel armour, 10mm lexan in low stress areas
    Frequency: 29.885MHz with a silvertone (http://www.silvertone.com.auwww.silvertone.com.au) military reciever
    Status: just needs armour.
    piccy of the early version with no armour or batteries mounted (and old version controllers) http://www.robowars.org/forum/album_pic.php?pic_id=606http://www.robowars.org/forum/album_pic.php?pic_id=606
      Robot Name: ZERO
      Drive: 2x 12v Drill Motors/gearboxes at 12v with 150mm wheels and a hub made from the guts of a drill chuck.
      Controller: 2 x electronize 15A and mixer
      Weapon: 2.5kg spinning drum powered by 12v drill motor. Approx speed 4000rpm.
      Armour: 5mm Ali with 3mm polycarb on top.
      Chassis: 15mm S/S box
      Status: just needs Electronize and weapon wiring completed
      I will be taking ZERO to Brighton on Sunday to gage reaction and get some feedback then will be looking to get to live events! Hoorah!
        Sorry Pic of ZERO on profile.
          Got some of my CNCd components now- pics on profile.
            Zero looks great Glen. Look forward to seeing it at Sheffied.
              Hey if Zeros going to Sheffield it can meet up with Conundrum Mk1. Zero looks like a good base to start with, wish i could have built mine as good as Zero.
              Chris - http://www.featherweights.org/forum
                Robot name: Little Hitter
                Power: 1x NimH pack 33.6volts +600g C02
                Drive: 2x 30v Drills motors 75mm dia wheels
                Controller: 1 Technobots h bridge dual channel.
                Weapon: Pneumatic axe. 80mm bore 50 stroke 16 bar ram(mounted vertically), paintball reg and buffer tank. 12mm pipes + 1/2BSP valve(3/2).Axe Shaft+head grade 5 ti.
                Armour: 1.5 mm front, 1.2mm sides, 0.6-1.6 back all grade 5+ ti.
                Chassis: 30mm nylon milled to 8mm in middle.
                Weight: 12KG
                Status: Finished. Going to sheffield.
                Pic on profile
                  Robot name: Little Flipper
                  Power: 1x NimH pack 19.2 volts +600g C02
                  Drive: 2x 12v Drills motors 75mm dia wheels
                  Weapon: Full pressure flipper. 50mm dia 60mm stroke hydraulic ram.1/2inch Burket,enough pipework for buffer/area of ram.
                  Armour: 1mm - 1.5mm all round,1.5mm where electrics are. 3mm flipper. All grade 5+ ti.
                  Chassis: 12mm Nylon + 0.6mm ti.
                  Weight: 11.9 KG
                  Pic on profile
                    nice
                      2 new feathers building. (1) Noname. 18v drill motors for drive. linier actuator with a 400kg pull/push for lifter. 2 x 12v 3000 nicads 2mm stainless steel and 4.5mm polypro armour. Will be at Magna.
                      (2) Ram bot with wedge Gold motors 6-1 reduction chain drive. 2 x 12v 3000 nicads. polypro and steel armour.
                        Im just starting the build of my new robot a push bot feather weight this time. See pic on profile.
                        Robot Name: Dont know yet havent decided. Maybe Mini Mayhem?
                        Power: 24V 3Ah NiCads
                        Drive: 2 drill motors powering 4 80mm dia wheels
                        Steering: Traditional skid steer
                        Armour: 3-5mm thk steel
                        Status: Design complete just starting build.
                        Richard
                        Team Mayhem
                          Oh forgot
                          Speed controller: IBC
                          Features: Drive train suspended from body to allow adjustment of scoop height & protect from distrotion in chasis.
                          Richard
                          Team Mayhem
                            pics look very good
                              Flipper
                              Current Version
                              Speed: 14Kph
                              Power: 1x 14v 3000mAh soldered NiMH Pack
                              Drive: 2x 9.6v Drill Motors
                              Controller: 2 x 30amp Electronize with external Relays
                              Weapon: High flow rate low pressure 10bar Pneumatic Flipper
                              Armour: 6&10mm Polycarbonate
                              Frequency: 40.685MHz
                              Status: Complete, Pic on Profile
                              Flipper
                              Upgraded Version (Parts are here but are not in the robot yet)
                              Speed: 18Kph
                              Power: 1x 16.8v 3300mAh soldered NiMH Pack
                              Controller: 2 x 30amp Electronize with External Relays
                              Notes: Should drive in a Straight Line!
                              Status: Needs to be assembeled.
                                Latest pics of noname on profile
