Featherweight Database
robot name: Kang
Power: 1x 12v cp2400scr nicad pack and 2x resoldered 12v drill packs
Drive: 2x 12v Drill Motors/gearboxes at 12v with 125mm wheels and a hub made from the guts of a drill chuck.
Controller: two 12amp custom made drill trigger servo controllers.
Weapon: 240mm saws, either 72 tooth or 50 tooth version powered by an ev warrior size motor at 24v (has a flat plate on it). speed is about 5000rpm ~
Armour: 10mm 5083 aluminium lid with 4mm steel armour, 10mm lexan in low stress areas
Frequency: 29.885MHz with a silvertone (http://www.silvertone.com.auwww.silvertone.com.au) military reciever
Status: just needs armour.
piccy of the early version with no armour or batteries mounted (and old version controllers) http://www.robowars.org/forum/album_pic.php?pic_id=606http://www.robowars.org/forum/album_pic.php?pic_id=606
robot name: Kang
