I moved the safety bar lower and it worked a bit, I think the camping pegs I was using are made of aluminum, 5mm thick. Will a steel bar be stronger?
BOB FW Series
Well, that was fun. 3 -2 is not a bad start to the year, even though we're in June now. I seem to have found the main reason why it hasn't been driving straight
Easy fix.
Well, this season's run of Robodojo for BOB 1 HD remix went well. Finishing 2nd overall and going through 3 or 4 motors, different thicknesses of steel for the lifting wage, making an anti-ogre lord top, getting some tools to do one thing, and a receiver.
One thing I don't think I'll be using again is the spare transmitter and receiver I got
https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1
It is rubbish and does not bind to other transmitters and receivers, also it keeps failing the safety check when you turn off the transmitter.
Well Done Sean !
it goes to prove that the more events you attend,the better your chances for points and high ranking
not to mention that not to be sniffed at Prize money for places 1 2 and 3.
I tried with others to help you with the transmitter but it was soon apparent there was a fault with that
transmitter.
