Team Shakesc : Build Diary
  • #76
    Thanks Nick, looking at some of the components you produce it certainly looks like it could do the business
    • #77
      Its been a while since I posted
      Spur 2 with the Dewuts tends to break the bolts between the sprocket and wheel on a regular basis
      I've moved to drilling out and using 3 x 4mm hardened pins held in with JB weld. Time will tell but I'm optimistic this will hold
      • #78
        Next thing is Spur 3
        Been working on this off and on , trying to decide how to do the drive
        Finally came down on aluminium bulkheads bolted into the chassis.
        I will be using Vesc's but for test some good old SimonK TZ85A will do
        Need to get the thread on the wheels and internal supports, top plate support, battery box and weapons system. So almost there then !
        PS: Still havent finished the kitchen
        • #79
          Well did a first test with some SimonK flashed TZ85a
          Being very overpowered gives it controllability , who would of thought it
          Change in direction is good and it bunny hops. Still trying to squeeze a weapon in. hehe
          https://www.youtube.com/watch?v=5_4ahUXIQ-k
          • #80
            Considering that's only on 5S and in a confined space, it's gonna be awesome at full chat! What's the current weight? And are you looking into magnets for extra traction?
            • #81
              I think we can agree that brushless up to the featherweight class is basically "confirmed" now! Looks good.
              • #82
                Need to weigh again, I'm going to use it all
                Have to build up the battery compartment and decide on the lid material (hardox or Ti)
                Plan to have side HDPE panels bolted on and add some additional thickness to the front buttress
                Like the thought of magnets and played with those before but need to get the strength right
                • #83
                  Here's a useful tool for getting magnets right; I used it for Incomplete Control and it's pretty spot on.. https://www.kjmagnetics.com/calculator.asp
                  • #84
                    Seeing all these robots now with hardox, would a swarm of microbots with magnets work?
                    • #85
                      See I was thinking this the other day. What if you entered like five or six featherweights as a heavyweight, and just slipped underneath the opponent and pushed them into the pit?
                      • #86
                        Imagine a feather being flipped by a modern flipper....
                        • #87
                          "that one came down with ice on it!"
                          • #88
                            You mean like Behemoth in Episode 1 of the new series? Or did you mean full pressure specifically?
                            • #89
                              Modern flippers, like Eruption , Kronic, Iron Awe and the daddy of those, Gravity.
                              • #90
                                Off to Stevenage with Spur 3 for its first outing. More of a test run as weapon is not finished. Also made a mess of my plastics order hence the clear lid (not for posing honest)
