I might have done with some more weight and grip, my only tactic would have been running away which in theory could have worked, but that's just a bit cheap isn't it?
Either way, I could only have own with that method if Endeavour went out somehow, since I believe they have the same size battery as I do but with less high amp draw motors (drills vs Johnson 51mm/speed 900s)
To be honest with you, I think we'll both have some scary machines next year if upgrades work out, yours will be much scarier like... HardWired II will fight again!
