Side strips to avoid getting stuck on its side 8mm aluminium water cut
No Toy Robotics
Ceros new flipper arm 6.35mm t6 aly with 5mm aly braces and 5mm ti sides with 20mm steel bar for the ram to work on just need to make the hardox snow plough,
bettle weight spinner under construction 500gram drum mounted on 10mm bearings
4mm hardox scoop cut ready for bending and nylon collar to reduce ram stroke from 120 - 97mm in design, should have a new update by next weekend,
notoy has new 4mm aluminium base and is about 50mm smaller length and depth, gr01 fitted and axe mount cut
Final test c02 using one of trevs regs, starts at 8bar up to 12bar, includes new 4mm hardox scoop shortened ram know have 95mm stroke still plenty, just using the steel single buffer tank. seatbelt arm restraint straps with 4x8mm bungee on each side to close the arm, also all final fitted armour.
enjoy
http://www.youtube.com/watch?v=CVy0KEioEaE
no toys new chassis gr01 motors and 2xspeed 900 axe motors and 4mm aluminium base
