Some really lovely little details on there, excellent work
No Toy Robotics
Quick update another bad weekend with ceros this time lasted nearly 2 minutes in its first and only fight of the weekend. But at least that is twice as long as the last fight. flipper working fine but drive seemed very slow. Just worked out the gear ratio and the max speed should be 11.437 mph with no losses but looked a lot less then that as tr2/and mm were almost twice as fast in the arena. not sure if this is down too the huge gearbox and drive losses with the gokart wheels or the the wotty problems we had.
any ideas, thinking of reducing the ratio from 19.4:1 to about 16:1 therefore giving around 14mph
any body used these npc motors, might make good single stage perm motor replacements little under powered but might just squeeze in
http://www.robotmarketplace.com/products/NPC-02446.html
NPC gear is generally good quality, although that motor looks like a generic Chinese design. For less money & weight, you can get the AmpFlow E30-150 Motor, which has more power and better construction. If you can deal with the extra RPM, it beats the NPC motor hands down. If you want more power, the AmpFlow F30-150 Motor still weighs less than the NPC one.
