Nothing wrong with a wall of text. Build diaries bring that out in people, mine's testament to that!
The ESC problem described sounds exactly as David said. If you're using Botbitz 85A ESCs with a Spektrum transmitter (or other make), the ESCs will cut out when you hit the diagonals. Something to do with the throws/stick travel when mixing etc.
But anyway, the amended code that has been developed appears to resolve the issue, and can be found here: http://www.fightingrobots.co.uk/thre...-spektrum-dx6i (link at the bottom of the first post).
If you're unsure with soldering to the ESCs or programming, there are a few folk in the community that can do it who can help you out, although it's reasonably easy to do it yourself. One thing worth mentioning is that if you got the ESCs direct from Botbitz, the motor wires will be at the top and bottom of the side of the ESC, but if you install the amended code I've linked to, it use the middle and top (or middle and bottom, can't remember which) connection points, so you'll need to solder a wire onto the board in the middle spot.
And glad to hear that you've had fun in your first year. Endeavour is a tough and well-built little cookie, look forward to seeing it again next year
