Thanks for the suggestions, but i with the help of Photoshop, i have a solution: a pizza themed robot!
It's name would be Pizza Cutter and it will have one wheel.
Thanks, i don't think anyone's used the name pizza cutter before.....
Here is a picture of a test model made from an old pizza base (hint, hint...) and below that is a basic test prototype made from an old hard disk platter and a scalextric motor (yes, i use pretty much anything to make robots!).
Thanks for the replies but i will not be entering the dutch robot games, so to me it is irrelevant that there are dutch robots with a similar/same name to my robot.
Pity, as it doesn't matter that much what name the robot carries to participate in the Dutch/Belgian/German events, you would been welcome.
I was just refering to the fact you're not that original with names.
Hello all, over the weekend i started on the 'un-named antweight melty brain spinner' mentioned on my profile. It doesn't spin very fast and is not radio controlled. I will add a Polulu Baby Orangutan and Saturn 9gram receiver, as my transmitter is a 5-channel saturn one so that is the only receiver that it will bind with (i think). Could anyone suggest a way of putting pictures on a post, as the 'attach file' doesn't work.
