Re: Pulverizer Build Diary
first thing is first, ask yourself how fast you want the robot to spin. From that work out what rpm you will need from a motor at a given wheel size. My big worry with the melty brain was that to get a decent speed I basically needed either a 1:1 or a 2:1 ratio after doing the sums. That meant a motor with a lot of torque. You also need to look at what you plan on powering the batteries with. Ideally lipo at 10s or similar.
With regards to the one wheel/two wheel arguement, well you could use a more powerful motor. You would have more difficulty in balancing the chassis overall for a balanced spin.
You also have to look at the size of mosfet you are planning on using for the on/off circuit. I'm going to assume you are using the open source material that I used for my play around.
The ampflow motors are good but I would recommend looking to see if you can go to one of the more powerful versions.
