Originally posted by Max
Pulverizer Build Diary
And? 2 meters of box section for £20, or 6m of the same dimensioned box section for £20.Originally posted by Mega Masher View PostJust saying, i will only need around 2 metres of tubing for this build.
Worst case scenario you'll sell the surplus for £5, and put £5 in your pocket.
But me, I prefer to have a surplus in my basement/workshop/gardenstoragebox.
I wouldn't attempt to bend it myself without the correct bender for square tubing, most probably it'll collapse, more so if its a thin walled section. But you could find a pipe bending shop in your area and they'll do the job for you, probably you won't even need to buy the material as they will have themselves.Originally posted by Mega Masher View PostTo be honest, i have no idea
It will be neater than if you try to cut/weld it to shape and saves you a lot of sweat!
ps. I dont know the local costs involved tho!
Breaking News:
Shred works!!!
I did some programming yesterday and it seems a lot easier than I thought it would be.
I will be working on the translation program soon, but at the moment, it just spins for a couple of seconds. Will upload a video soon, but wish to talk about something that happened alot during testing. After 5 seconds of spin time, the Banebots wheels would fall off the robot and go bouncing around the kitchen floor, because the grub screws came loose very easily.
Would a threadlock or someting stop this from happening?
Yes Max, I do understand what you mean and I have filed a flat on the motor shaft about half way down, so there is less of a chance of it coming off.
Was going to do a test video today, but battery's gone flat
. I'm also going to get another battery, but this one has 2000mAh, compared to just 700mAh in the old one, and a switch so I don't have to keep unplugging the tough tamiya connector
By the way, the robot called Cookie Cutter in my profile is my antweight spinner robot, except it only uses one motor to drive it. It is only 3inches in diameter and 1inch high. See pictures below:
http://i1280.photobucket.com/albums/...ps9b05390b.jpg
http://i1280.photobucket.com/albums/...ps15177793.jpg
http://i1280.photobucket.com/albums/...ps89a6deff.jpg
Update:
Shred
Been testing Shred lately and have upgraded the weapon
http://i1280.photobucket.com/albums/...psfaf23599.jpg
http://i1280.photobucket.com/albums/...ps5f282fa9.jpg
http://i1280.photobucket.com/albums/...pscdc6f48b.jpg
http://i1280.photobucket.com/albums/...ps2d2c549d.jpg
http://i1280.photobucket.com/albums/...psd56d647a.jpg
The wheels seem to stay on longer now I have cut a flat across the grub screw, so can tighten it more. Switch has been added - a 10amp @ 250v 2-way toggle switch - seems a bit overkill, but 'better safe than sorry'. http://i1280.photobucket.com/albums/...ps9c1538ee.jpg
http://i1280.photobucket.com/albums/...psbd278e76.jpg
Cookie Cutter
Did a brief test run off some AA's and seems to run pretty well
Pizza Cutter
Bought 2 100mm diameter castor wheels from Clas Ohlson. http://i1280.photobucket.com/albums/...ps326f8f58.jpg
Will use 4inch Colson Performa wheels for competition, but these should do for now. Drawn up a 1/2 scale diagram of Pizza Cutter, and all looks like it will fit. Will upload more pics soon.
Sorry for the long post, but that's what I've been up to.
Well, when I say 300rpm, I don't know for sure. I'll know for sure when I fit the accelerometer. To fit said accelerometer, I will use a modified version of a J2O bottle lid.
http://i1280.photobucket.com/albums/...ps754eb0e9.jpg
http://i1280.photobucket.com/albums/...psfafc2b64.jpg
I'll cut some foam to fit the inside of the lid, then put the accelerometer in with the wires all soldered, and zip-tie it all down.
http://i1280.photobucket.com/albums/...psfc59ba88.jpg
http://i1280.photobucket.com/albums/...ps28631296.jpg
