Team Bodge Job
    Re: Team Bodge Job
    It's an add on of bruiser 1, sadly I can't make the champs this year, going try and make the other rc event, but it's still not likely I'm going to be going. And I know, loads of new axes, if I'd have know I'd have made something else. Luckily it's easlily removable, so I can build different add ons later!
      Re: Team Bodge Job
      woops
        Re: Team Bodge Job
        And now we've managed to snap the remainder poking out off. The nylon must have really hardened up in the cold!
          Re: Team Bodge Job
          other than fixing the axe head on I have pretty much finished the axe unit, mounted the sprocket and motor, and tensioned the chain.
          should be able to get it running tomorrow, although I have somehow run out of solder so will be tricky unless i find some. and cant decide whether to hold the axe head on with 3 small bolts or 2 large ones?
          would 2 or 3 be stronger?
            Re: Team Bodge Job
            Looks good
            but you might want to support the motor shaft as it might put to much strain it swinging that axe
              Re: Team Bodge Job
              yeah although there's not really enough of the shaft sticking out to do it (that bolt is only on a few millimeters so needs to be trimmed down. and the sprocket cant be moved up the shaft as its too small. I could put a bearing on the boss of sprocket I sopose. Will worry about that later.
              thanks though, its a good idea though
                Re: Team Bodge Job
                just did a quick test a 12 volts and its pretty powerful and fast! its gonna be great at 18 volts! although im going to have to solve the issue of the impacts on the frame, may need to stick some rubber on it!
                • #23
                  Re: Team Bodge Job
                  Quick video, although its badly edited, and pretty rubbish, oh well ill put up a better one ones its working.
                  I have completed fitting the axe, and shaped the axe a little as well (although that was after I filmed the video.
                  http://www.youtube.com/watch?v=MP7IU6WucZY
                  As you can see it was only driving in one direction as I was running it off a car battery, and was very wobbly as I was trying to film it while crouching and operating the axe.
                  • #24
                    Re: Team Bodge Job
                    And some photos
                    • #25
                      Re: Team Bodge Job
                      nice job looks good need morter axes bodge job + notoy vs the world !!!!!!!!!!!!!!!!!!!
                      • #26
                        Re: Team Bodge Job
                        yeah thanks, I like axes! and any one know how i can get the video to work?
                        • #27
                          Re: Team Bodge Job
                          Impressive! Is that a 36:1 Gimson?
                          • #28
                            Re: Team Bodge Job
                            i would put a small cover over the motors if i were you
                            • #29
                              Re: Team Bodge Job
                              yeah, im surprised at how powerful it is, and i have the parts to change it to 24:1 so I might give that a test sometime. The chain also provides 5:1 reduction. and yeah im not gonna leave them open, im making a new top and back, and keeping the old parts to use if the axe breaks.
                              • #30
                                Re: Team Bodge Job
                                That's amazing! Really makes me want to get my axe built. To echo the other comments, I never expected a GR02/drill motor arrangement to be that effective. And all this time I've been messing around with beefy scooter motors and Bosch 400s
                                To get your video to work, you need to have the full unaltered Youtube address within those [youtube] brackets, rather than just the abbreviated address. Doing so will embed the video, like so:
