well my welder is actually mig, and i did a lot of testing with the other burn out motor, the insides seemed to turn out fine, i think the brass busing seemed to help act as a heat sink, and the gear seemed to turn out fine and it hasn't weakened a noticeable amount (i tested it thougherly with a hammer) and the weld I did could be ground down enough to fit in the gear box and work.
when i did it on the actual motor and gear it worked fine, just got a small amount of the weld to close to the teeth, so i will have to file that down and sort it out when i have access to my good needle files and dremel. I have tested the motor (out of the gear box) at it all works fine. so im pleased with the results. just will have to test it properly when i have finished.
thanks for the advice though.
