Re: Build Diary and some questions that may appear - BW/MW
My first RC car charger was like that, it should turn green when its done Normally those chargers will discharge battery's when unplugged from the walls. And if it doesn't go green after a few hours, you can try to keep it charging, but keep an eye on it, make sure it doesn't get too hot. and if it doesnt go green after like 5-6 hours i don't think its ever gonna go green. If its advertised as a charger though it should go green, and float charge when its done (which means it doesn't over charge them).
hopes this helps!
hopes this helps!
