Team Bitza
  • #31
    Re: Team Bitza
    What's the catch?
    http://www.ebay.co.uk/itm/Solid-State-R ... 35bb7a92d5
    I stupidly blew the nice (albeit fragile!) Jaycar SSR we use for weapon control (reverse polarity, d'oh!) but at a 3rd the price what am I missing?
    • #32
      Re: Team Bitza
      Output voltage: AC 24-380V
      Output current: 100A
      Input voltage: DC 3-32V
      Control Method: DC to AC
      That's your catch :wink:
      Whether it has the potential to work like a Jaycar SSR I don't know (depends on the internal make-up). I'm not so clued up on cross compatibility with things like this.
      • #33
        Re: Team Bitza
        Doesn't the jaycar one say a similar thing? I'll have to dig out my blown one. I figured the load side was just a big switch AC or DC?
        • #34
          Re: Team Bitza
          From the Jaycar website:
          http://www.jaycarelectronics.co.uk/prod ... ?ID=sy4086
          Output Circuit
          € Load Voltage: 0-30VDC
          € Load Current: 0.02-100A
          € Max On-State Resistance: 0.007Ohms
          € Max On-State Voltage Drop: 0.35V
          € Max Turn On Time: 0.5ms
          € Max Turn Off Time: 0.5ms
          € Max Surge Current: 240A (10ms)
          Input Circuit
          € Control Voltage: 3-32VDC
          € Control Current: 28mA max.
          € Min Turn Off Voltage: 1.0VDC
          € Input Resistance: 1.2kOhm
          Doesn't appear to be any mention of AC here, but again, I'm not sure if they can be used for both.
          • #35
            Re: Team Bitza
            It appears Jaycar do 2, one with a VAC output and one with a VDC.
            Searching SSR on eBay and omitting VAC brought up some results, although finding a DC one (that actually is!) with a decent amp rating (80s +) is porving impossible let alone a good price.
            This is the best I could do:
            http://www.ebay.co.uk/itm/SSR-60DD-DC-t ... 20cd90f6c6
            60a
            And 80a at a premium:
            http://www.ebay.co.uk/itm/Solid-State-R ... 230ffeaafb
            • #36
              Re: Team Bitza
              PJ, I have another of the ones I sold you a while back, would you be interested in that? I don't have anymore spare so don't immediately blow it up this time
              • #37
                Re: Team Bitza
                Hey Tony, that would be great! I'll try and make this one last longer!
                • #38
                  Re: Team Bitza
                  I need to regulate the 24v in Bitza down to 12 for some cooling fans what's the best way to do this?
                  Most BECs regulate to 6-8v, or boosters increase voltage. Anyone know of a solution?
                  I doubt the current draw would be much so resistors could be a possibility?
                  Found this:
                  http://www.blackfiveservices.co.uk/fans ... &Target=12
                  • #39
                    Re: Team Bitza
                    http://www.technobotsonline.com/hv-s...regulator.html
                    Would this do?
                    • #40
                      Re: Team Bitza
                      Bit pricey but thanks for the link.
                      Given the low current draw of the fan I'm hoping a resistor will do but without knowing the exact amperage I can't calculate which resistor. Time to experiment!
                      • #41
                        Re: Team Bitza
                        Stuff on ebay cheap
                        http://www.ebay.co.uk/itm/NEW-DC-DC-Adj ... 43b01c45c5
                        http://www.ebay.co.uk/itm/New-LM2596-DC ... 231ed973f5
                        • #42
                          Re: Team Bitza
                          Putting 2 the same fans in series is the most easy way to do it.
                          • #43
                            Re: Team Bitza
                            As mario say's either 2 fans in series, or just put a resistor on. Those Jaycar SSR's are the cheapest I ever found - although fragile they don't seem alot different to the £80 ones we got from RS years back.
                            • #44
                              Re: Team Bitza
                              Good find Chris!
                              That's a good point Mario but I've really only a need for one fan, worth bearing in mind though.
                              • #45
                                Re: Team Bitza
                                How big a fan do you need? I have a brand new 24v fan for my victors which I don't need (seem to run fine without them) if you'd prefer to run it off battery voltage.
