I need to control, via R/C what I believe to be a SPDT/CO switch...
The actual switch has three positions, centre is off left is on on and right is the other. Can someone advise a suitable RC switch to control this please?
THATS my kind of robot
that's like 20x more powerful than gimsons
i don't beleive it will work but just hope someone is clearing out their cellar and saying,
do i really need this binfull of rare earth magnets.
3hp isn't going to stick to the floor
and guess what.
USLESS POINT OF REFERENCE: http://shop.mobileweb.ebay.co.uk/search ... Kw=true&cm
d=SREF
nope
No magnets, unless we happen to find some, we do have some incredibly wide wheels though!
So what sort of top speed do people aim for? Cobalt seemed a good speed, Satanix perhaps too high, the new Aftershock had good drive, 540 moved like a fly!
i think its good to have a higher top speed than you would maybe use all the time, however you don't want it crazy so you can't control it. Plus i'm guessing you'll only be using this in the RC arena which isn't huge so i think 10mph top end would be good
PMDC motors have the following characteristics:
They produce their maximum torque at zero RPM.
They produce zero torque at their maximum RPM.
They develop their maximum horsepower at 50% of their maximum RPM.
At 50% of maximum RPM, they produce 50% of their maximum torque.
At maximum horsepower, they are no more than 50% efficient.
Given these statements would it be a good idea to gear for a top speed double what you want so you're running 100-50% Torque and 0-100% Horsepower over the speed range you'll actually likely achieve?
No... The balance to be made is between torque and speed, making your gear reduction half what it would otherwise be will slow you to a ridiculous extent as your acceleration would be hopeless. 'Horsepower' doesn't really matter, it's just a hint at torque/speed characteristics which you should be designing around. The best thing is to use the tentacle calculator to try some gearing combinations with a motor similar to yours, and enter a realistic tire coefficient then you can click the 'acceleration' button for more information: http://www.architeuthis-dux.org/torquecalc.asp
