It weighs a fair amount, my guess would be around 4kgs, but I'll stick on the scales in a bit.
That's an off cut too of what he had!
My plan is to bore out the middle to 20mm, make it a lot shorter and effectively use it as a stand to hold a 20mm Silver Steel shaft that will support the wheel.
The flat top will make a nice surface for a thrust bearing and it's size will means lots of mounting options.
Although looking at the build pics of Tetanus it may be a little overkill, very conscience of weight.
