I'll have a look at the electronizes this evening, I've had a rethink on the layout for the heavyweight, I've dropped one of the main tanks and replaced the other with a longer thinner bottle.
I have lost the 'ideal' flow setup from the buffer like I had before but this way is much more compact so can be better armoured. I'll make the pipes from the buffer to the ram 3/4" rather than 1/2" to increase flow around the bends. Is it true that a 90 degree bend halves the flow, I find that hard to believe
