Re: Team MedBots
I've been working on trax (fw tracked robot) today which uses wiper motors . The problem is I am not sure how to attach anything onto the output shaft (small threaded shaft) currently I have a bit of steel rod with a tapped hole to screw onto the shaft and then a horizontal hole for a split pin to go through and a corresponding hole on the wiper shaft. But my split pin keeps snapping and I've tried a small bolt and that just snapped as well. How do most people attach anything to these shafts?
