Team MedBots
    Re: Team MedBots
    or go brushless its cheaper and faster.
    Check giant cod
      Re: Team MedBots
      PJ- what make did you say your fan motor was? And how much did you pay for it?
        Re: Team MedBots
        It's a Bosch, all Vauxhalls have them. Paid £1.
        One of the more expensive parts in Bitza......
          Re: Team MedBots
          Speed 900s have a nominal voltage of 12v, but will run on 24v without much fuss. I imagine the replicas function the same.
          As regards to fan motors use a Bosch 056, you can get it out of ford mondeos. 282w peak power at 12v, 1.6kgs in weight.
            Re: Team MedBots
            the whole brushless setup will be £50- and will be light and small and efficient.
            cheaper than speed 900s.
            my dad found a car fan which worked but it was quite bad.
            your choice
              Re: Team MedBots
              http://www.giantcod.co.uk/xyh5065-380kv ... 02747.html http://www.giantcod.co.uk/speed-control ... 02445.html
              there's a cheap setup
                Re: Team MedBots
                maybe in magic land
                • #23
                  Re: Team MedBots
                  what's wrong.
                  brushless is still good right
                  • #24
                    Re: Team MedBots
                    terible esc will probably bust into flame and melt as soon as you blink near it, and what looks to be a pretty sub standard motor for this purpose.
                    brushless is good, hell i am going to be using brushless in a fw but leave these things to people who know what they are on about(not in anyway saying i am one, not by a long shot )
                    • #25
                      Re: Team MedBots
                      OK
                      I know fans are rubbish.
                      • #26
                        Re: Team MedBots
                        With brushless, you tend to get what you pay for. If a reliable and good-quality brushless setup cost just £39, then everyone would be using them. But they're not, which speaks volumes for the reliability and quality of the above brushless equipment. Maybe alright for planes (for which they are designed) but not for robots.
                        One downside with car fan motors is that they're second-hand and come in varying degrees of condition. But if you get a decent one, it will be as good a power source for a spinner as you can get. Dragonstrike uses them to good effect, and more recently (although briefly :wink: ) Bitza Mk.2.
                        • #27
                          Re: Team MedBots
                          Jamie, you went brushless in drumroll right? How much did you pay for that set up?
                          • #28
                            Re: Team MedBots
                            I did indeed. The cost was as follows:
                            Scorpion motor: £85
                            Hobbywing 150A ESC: £68
                            Lipo batteries (not an essential part, but it's hardly worth going brushless without them): £40
                            Total: £193 (£153 without lipos)
                            Not cheap but definitely not the most expensive setup around. The motor I used was a Scorpion HK4020-1100kV model that I got off an eBay seller, but he doesn't sell that specific model now. The closest model would be: http://www.ebay.co.uk/itm/Scorpion-HK-4 ... 470wt_1037
                            I think that's the same motor that 540 uses. The 4025 range has slightly more power than the 4020 model I'm using.
                            The speed controller is this: http://www.ebay.co.uk/itm/Hobbywing-EZR ... 139wt_1037
                            Recommended to me by Graeme from the Big Nipper team; they ran it in Buzzbar last year with a massive motor. Didn't once let me down last weekend and is still running well, although it is quite over-spec'd. It's got a low-voltage cut-out built-in so that you can protect your lipo batteries from over-discharging, as well as several other adjustable/programmable settings. Definitely a worthwhile purchase for anyone looking to go brushless.
                            • #29
                              Re: Team MedBots
                              LS4 is running a HK-4035 Scorpion (around £120 on ebay) and (i think) a £180 ESC, then 2 5 cell lipos joined together permenantly to form one 10 cell, then the 10 cell charger on top of that... around £400-500 depending on where you get it all from.
                              I was thinking of going brushless next year but I have bigger issues to solve atm, like raising my disc up and stopping my Speed 900's from going up in a big plume of acrid smoke.
                              edit: and replacing the whole base plate on conker
                              • #30
                                Re: Team MedBots
                                http://www.hobbyking.com/hobbyking/stor ... oduct=5139
                                take it this is a cheap one.
                                9 horsepower
