Re: Team MedBots
Gears are cut to have the right play when the holes are drilled perfectly concerning the pitch diameter.
But if you want to do the drilling of holes for gears artisan style, a mod 1 pair of gears can benefit from a piece of sigaret paper in between the gears.
Also, to make the calculation for you, I need to know the module.
Or you do as I, and open your smartphone, download the Dennis Martens Gear Spacing Calculator (not in the google play store, it's being spread by Email), and fill in the 3 numbers. Module, Gear 1 and Gear 2
On the relais. A closed relais can take +/-15 amps per 1mm² of contact surface. But it's breaking contact that makes the difference. The lighter the moving contact part is, the faster it can move, breaking the arc fast, but the instant an arc is formed, you're welding or spark eroding the surface.
It's how the 4QD's NCC 70's work with a 40 amp relais. The fet closes the power to the relais. The relais switches, and the mosfet pours in the power again. That means even a cheap relais can switch a far heavier load than what it could do on its own.
