scruffy
at the moment i cant decide whether to have a 3mm welded top with everything mounted to it and a removable base plate to get access.............or to do what i did with scruffy 1 and have the base plate welded in and everything mounted to that and make the top plates removable
the main bonus with scruffy 1s version was that it was easily replaceable if it got damaged and there was an air gap between the top and the components but with the other idea it would be lighter and i could put a sacrificial layer of polycarbonate or hdpe
any advice anyone ???????/
scruffy 2 has moved along a bit more the actuator has been moved right up the front just behind the face which puts it 1/2 and 2/3 from the pivot once the front of the lifter is added
i also intend to put wheel arches to protect the tops of the wheels at the moment i cant decide whether to use a chunk of steel tube, as i have some 100mm di tube or to do something more like bigger brother
ok done some more over the weekend, i cut the aluminium base plate but cant find my m6 tap so cant fit it but i have ordered a new 1 so will get that done later and i have now made the wheel arches and started on the lifter front which kinda reminds me of a platypus at the mo, also i'm going to have sloped edges down the sides of the lifter to deflect spinners
i still have to make the battery box, horns and finish off the scoop before i can paint it but im hoping i can get it ready for guildford
ok got the link,fuse,esc,battery + box,horns and power splitter fitted and i've also got a the plate on the back of the lifter fitted and a good chunk of the front done
ive still got to put sloped sides on the lifter, bolt on the titanium blade at the front wire up the lifter (which is going to be the biggest pain) and add all the goth spikes
so off to make some CAD templates for sloped lifter side
