Metalbeak (FW) Build Diary
  • #31
    Re: Metalbeak (FW) Build Diary
    Originally posted by jonny
    looks pretty, what are the dimensions?...what is the big silver lump attached to the buffer tank?
    Umm... no dimensions yet; waiting until I have everything to start on that, and the lump is the ali blok connector.
    Got a flat design now, brand new paint scheme:
    [attachment=0:e9136bwo]Picture5.png[/attachment:e9136bwo]
    • #32
      i think that is a much better design jarvis, and the painjob will look brilliant. what are you going to make the sides out of, 10mm hdpe?
      • #33
        Going to go for 12mm actually, just to be safe. 12mm armour, 6mm base, all black, with a steel flipper.
        • #34
          nice, i use 12mm, its good stuff
          • #35
            much better! go for a 8mm thick plus hdpe base (i'm using 10mm) as that ram will give a hell of a kick
            • #36
              Thanks for that Jarvis, and I think you have made quite a good scheme there
              • #37
                Originally posted by MicroGravity100
                Completely redesigned Metalbeak in DT today for easy building, space, and a wider weapon:
                i liked your first design
                • #38
                  I did too, but it was far too difficult to build.
                  • #39
                    worth it
                    • #40
                      More pneumatics:
                      • #41
                        Good looking pneumatics
                        • #42
                          20oz Main Tank Arrived today:
                          • #43
                            i have a tank like that,how are you going to attatch it to something?
                            • #44
                              Got a connector on the way.
                              • #45
                                remember electronizers arnt easy to drive (bulldozer is a example) :P
